Depending on who you ask the min. is 8, but the pro's say 20. Elsewhere I have found that for any tool, you should have a compressor capable of 50% more than the tool demands. For example, a tool needed 6 CFM should have a compressor rated at 9 CFM. From the Mactool webside for compressors: Impact wrenches require anything from 5 to 20 (3/8; 1/2; 3/4). body sander, bead breakers require 12. HLVP paint spray is listed at 15. The craftsman site seems to indicate much small rates.
https://members.tripod.com/~bobstory/faq.html#CFM1
18.2. WHAT SIZE AIR-COMPRESSOR DO YOU NEED TO PAINT A CAR?
The compressor should be capable of delivering a minimum 20 cfm at 90 psi.
30. Compressor PSI
30.1. but it only put out about 9 cfm @ 90 psi. Am I nuts to hope to do any painting with a rig like this? It looks like a two stage almost doubles the price. Let's assume I'm not after a show quality paint job. I'm considering painting an old
You can, but it will be awkward. When your pressure drops the paint will not atomize well, and will orange peel. If you wait for the pressure to build up, the paint will dry and you will have dry spots. Maybe if you do it in sections?
18.1. My question: WHAT SIZE AIR-COMPRESSOR DO YOU NEED TO PAINT A CAR? Will a 25 gallon 5hp compressor work for painting that has a 5 SCFM @ 90 psi / 7.5 SCFM @ 40 psi. If so, any limitations? If not, what kinds of problems will I most likely encounter?
You will run out of air. This will lead to dry spray areas, since you will not be able to paint fast enough to keep the surface wet.
But other sites reference the following:
https://www.theautoist.com/body_repairs.htm
A compressor that can produce at least 8 cubic feet a minute flow at 40 PSI with a 20 gallon tank. Horsepower and compressor type don't matter, the above specs do. This little compressor won't keep up with any air sander, but it will a paint gun or any pneumatic powered wrench in a home tool box.
