Intresting compressor story
jlaird
Got the parts yesterday. New Piston, rod and sleeve, new intake and exhaust valves. Installed all. Started fine and pumped quickley to 80 lbs when I shut it off to check temps.
Could not then get the motor to turn the compresser to restart. Drained take of pressure to about 10 lbs and started fine. Fore some reason the elec motor does not like the load on start up.
I am going to have to talk to the manufactures tech line, I got to be missing something here. Oh yea, pumps like a crazy witch, really fast.
ChrisS
When the pressure switch reaches it high set point it should unload the discharge side of the compressor. How did you stop the compressor? If you flipped the lever on the side of the pressure switch it should unload as well. If you pulled the plug it will not unload and then struggle to start when you plug it back in. My small portable does this.
Does it has a no-load bypass for startup?
jlaird
jlaird
I see no bypass, both gages read the same all the time, bet that is the prob. Ahh, it is hidden under the regulator, will check.
Off to the Doc. will let you all know of resolution. That makes so much sense I should have seen that myself.
jlaird
jlaird
Ok, more tests gave the check valve a swat and it did work one time soooooo.
Going to order a new check valve, and unloader valve.
We will see.
dklawson
Some compressors have a remotely mounted unloader valve. If you don't find it easily, look for a piece of small bore tubing running down from the cylinder head(s) towards the pressure switch area.
jlaird
jlaird
Yep, that's what I got. Just ordered a new one along with the check valve and the tube. Now if I can just get the regulator to work, if not I'll get a new one of those as well.
aeronca65t VW History....intresting Other Cars 5
jlaird Intresting Spridgets 0
jlaird Very intresting problem, miss. Spridgets 8
jlaird Intresting noise Spridgets 13
M intresting offer!!! MG 2
jlaird Intresting Spridgets 3
jlaird Intresting note Spridgets 8
jlaird Intresting morning Spridgets 5
jlaird Intresting problem and question here Spridgets 11
jlaird Found an intresting pump Spridgets 0
jlaird Today was intresting Spridgets 1
jlaird Something I find intresting Spridgets 5
jlaird This is going to be intresting Spridgets 10
jlaird Very intresting Spridgets 8
jlaird Very intresting day Spridgets 3
jlaird Intresting info Spridgets 0
jlaird I find it intresting that Spridgets 5
jlaird Intresting problem Spridgets 32
jlaird Florida is intresting - Register your vehicle here Spridgets 8
Webb Sledge Intresting MG Fact MG 7
2 For Sale Dr. Doolin Spring Compressor for TR3 Triumph Classifieds 0
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
B TR6 TR6 AC compressor bracket Triumph 15
KVH General Tech Bleeding Brakes—Venturi/Compressor Triumph 8
TomMull Scroll Air Compressor Restoration & Tools 13
M For Sale Churchill 18G106 Valve Spring Compressor for Austin Healey 3000 Austin Healey Classifieds 0
dklawson New [to me] Compressor - Water & Auto Drains Restoration & Tools 14
S TR2/3/3A Air compressor crud Triumph 7
wangdango air compressor? Restoration & Tools 8
Jim_Stevens Off Topic Saylor-Beall air compressor on ebay Triumph 3
G Portable 12V DC Air Compressor Austin Healey 6
TomMull Air compressor help needed Restoration & Tools 2
J How to sell a LARGE Compressor?? Restoration & Tools 8
KVH Air Compressor Restoration & Tools 2
TomMull Air Compressor Solution? Restoration & Tools 8
K TR6 Spring Compressor [Atlanta area??] Triumph 10
A TR6 Spring compressor Triumph 16
B Compressor plumbing and accessories Restoration & Tools 11
JodyFKerr Tips & tricks on installing upright air compressor Restoration & Tools 15
Got_All_4 Wedge TR7 AC compressor source? Triumph 21
F Who needs a Spring Compressor... Spridgets 12
ekamm TR2/3/3A Tr3 coil spring compressor Triumph 20
DNK Spring Compressor Triumph 9
H Coil Spring Compressor Triumph 10
M Air Compressor Noise Spridgets 16
M Sandblaster/air compressor Spridgets 22
T Air compressor min CFM for media blasting Triumph 14
Jim_Gruber Air Compressor Motor has crapped out-thoughts Spridgets 19
Mickey Richaud Strut/Spring Compressor Restoration & Tools 10
