bash
I finally picked up a compressor last night at Sears - it is a 15 gallon 3hp peak (1.5hp running, I think) Craftsman, usually $200, reduced to $90 (floor model). I really wanted a bigger one, but for the price I couldn't say no. The problem is that it has no instruction manual, and the parts department either couldn't help or (more likely) couldn't be bothered to help with a replacement, so I would be grateful if you knowlegeable types could fill me in a bit!
I bought a 50ft 3/8" diameter hose - is that the right size to go for? The coiled types look too small, and I would think you would lose a lot of pressure?
There are two gauges, one says regulated and the other tank. I tried turning the knob between them but it doesn't seem to do anything... The needle on the regulated side stays the same as the tank side. I suspect that I am being an idiot - can anyone tell me how to regulate the pressure?
Any other tips would be most welcome too. I guess I won't be able to do any blasting with such a puny motor, but other than a ratchet and impact wrench, are there any great air tools I should be looking for?
Thanks as ever for your help!
Alistair
Alistair
