air compressor H2O problem
Jerry
I have a 5 hp compressor with 80 gal tank made in China. The unit makes compressed air well but lots of water comes through the hose. I have a NAPA water separator prior to the hose (tank-separator-hose) which seems to never collect water. The separator cost $85 so I expected it to work. Do any of you have any suggestions. The water plugs my bead blaster.
Jerry
TR3driver
Great Pumpkin - R.I.P
Most likely, the problem is that the air is still warm when it passes through the separator (meaning the water is still vapor), and then cools in the hose to condense to liquid. The separator will only remove liquid water.
One solution is to make your own chiller, which can be as simple as a coil of copper tubing in a 5 gallon pickle bucket or similar, plumbed in before the separator. When you get ready to work, dump a bag of ice in the bucket.
weewillie
This may sound stupid but you do drain the tank every day or night don't you.
J
Jerry
Good info on this site. I will try some of these ideas. I do have a plastic coil that I can put in a water bucket and then to the separator.
Also, I don't drain the tank every time. I will have to mark that down as a daily task.
Jerry
bill_young
A hint I learned from a guy where I work, if you use some common plumbing pipe to extend the drain out from under the tank it will both make it easier to drain and also easier to remember since it's no longer a "chore". Place a common ball type valve in line and turn the end down and you can easily collect any liquid in a bucket.
TR3driver
What I did was leave the line down near the floor, so I could operate the valve lever with a toe. Kept meaning to run the outlet outdoors, but never got that part done (so it just runs out on the floor and dries).
The new setup will have two automatic drains, one on the tank and one on the first drop leg near the compressor.
weewillie
I have an automatic drain on mine and when the pressure drops below 5lbs it opens and drains the tank
tomshobby
When you make the connection for your hose use a tee and a down pipe with a petcock drain.
Connect the tee to a horizontal pipe using the middle leg of the tee. Make the pipe down from the tee about 10 inches and run the hose off the top vertical opening of the tee. This will collect most of the moisture in the down pipe. Just open the petcock once in a while while you are working.
PAUL161
Sold by Van Air Systems, this automatic drain devise works so well, there is zero loss of air pressure. It requires no electricity and works off of air pressure in the system. Install it and forget it. Not cheap, but what is!
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
TomMull Scroll Air Compressor Restoration & Tools 13
S TR2/3/3A Air compressor crud Triumph 7
wangdango air compressor? Restoration & Tools 8
Jim_Stevens Off Topic Saylor-Beall air compressor on ebay Triumph 3
G Portable 12V DC Air Compressor Austin Healey 6
TomMull Air compressor help needed Restoration & Tools 2
KVH Air Compressor Restoration & Tools 2
TomMull Air Compressor Solution? Restoration & Tools 8
JodyFKerr Tips & tricks on installing upright air compressor Restoration & Tools 15
M Air Compressor Noise Spridgets 16
M Sandblaster/air compressor Spridgets 22
T Air compressor min CFM for media blasting Triumph 14
Jim_Gruber Air Compressor Motor has crapped out-thoughts Spridgets 19
Lin air compressor Austin Healey 12
Tinkerman Air Compressor Help Triumph 22
jlaird Progress, air compressor Spridgets 7
bash Air compressor advice, please Restoration & Tools 18
sparkydave Air compressor maintenance Restoration & Tools 3
Y Air Compressor Recomendation Austin Healey 13
N Good Deal on Shop Air Compressor Restoration & Tools 9
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
D Wire Wheels and Air Leak Austin Healey 16
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
PC air back there... Spotted 0
S TR2/3/3A restore my original air filters Triumph 5
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
E MGB Oiling foam air filter MG 3
E MGB SU carb air cleaners MG 10
