Waterless Coolant
Rob Glasgow
I watched an episode of Wheeler Dealer tonight about a TR6. They did a unleaded conversion to the head and when they assembled the engine, Ed used waterless coolant instead of water/antifreeze. He explained the procedure and benefits.
I looked up waterless coolant and found an episode of Jay Leno's garage on Evan's waterless coolant. It looked very interesting. I had never heard of the stuff although Jay said he had used it for 16 years.
Does anyone here have any experience with it. Good or bad?
57_BN4
I used a type of waterless coolant once- it completely ruined an engine. I think it was called laziness.
Jeepster
If its good enough for Ed China............!
its good enough for me!
not used it myself but I have heard good reports. It's not cheap though.
Superwrench
Used it in race cars and it worked fine. Never put it in a classic that sits around most of the year. Sounds like the big buck guys are using it in theirs.
Cottontop
From all I have read, it's kinda' like nitrogen in the tires = BIG cost... Little ACTUAL benefit.
Tim
bob hughes
Tim
Yeh, what's this nitrogen in the tyres lark? took the Audi to get re shod with new tyres and they stuffed nitogen in, does it make the car lighter ? -- :crazyeyes:
:cheers:
Bob
MikeP
In theory the pure nitrogen will not leak as fast and stay more pressure stable as the tires heat and cool. Plus it's dry, no moisture, so less potential corrosion of the wheel. If this makes a noticable difference in street use tires over just air, which is almost 80% nitrogen itself anyway, opinions seem to be mixed. Shouldn't hurt anything but you'll have to decide if its worth it.
Rob Glasgow
Rob Glasgow
The thing that caught my attention about the waterless coolant is that the boiling point is somewhere around 375 deg. According to the video, this means you don't have to worry about boil over and you don't need a catch tank. Also, since it's waterless, there is no build up of steam so you don't have much pressure in the system when operating. You can remove the radiator cap at any time without worrying about pressure buildup. Sounds almost to good to be true.
HealeyRick
57_BN4
"Their MSDS (Material Safety Data Sheet) states that it is 70% Ethylene Glycol and 30% Propylene Glycol ... I did look up the MSDS for PG and sure enough it will self ignite at about 699 degrees F. Thats a lot less than the temperature of the engine headers."
That's me out. Two gallons or so of flammable liquid up front where once was water doesn't sound so appealing, no matter the benefits.
At least it'd smell nice. While driving in Sweden during winter months the windshield washer contained aqueous propylene glycol which smells like hospitals when cleaning the salt film off the screen.
Propylene glycol is the ingredient in some 'environmentally friendly' antifreezes (e.g. 'Sierra' brand). Ethylene glycol is the ingredient in 'regular' antifreeze.
No magic formula here--looks to me like the Evans stuff is more clever marketing than anything.
drambuie
One of the first things that caught my attention when hearing about the high boiling point of waterless coolent about 375 degrees....what if you had a over heating issue and your temperture gauge was not working or you just where not looking at it! At least a 50/50 mix of regular coolent would boil over giving you some warning before toasting your motor! If i remember the boiling point of regular coolent at a 50/50 mix is 265 degrees/129 degrees celsius.... depending on your radiator cap rating. Am i missing something here? Michael,IL.
Boink Waterless Coolant - thread from the AH forum Spridgets 18
W Waterless Coolant Austin Healey 4
RAC68 Waterless Coolant Austin Healey 29
Keoke Waterless Coolant Austin Healey 12
S TR6 waterless coolant Triumph 6
me61ic Waterless Coolant Austin Healey 3
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Scotsman TR2/3/3A Waterless Coolants Triumph 15
S Spitfire Cyl head coolant hose fitting Triumph 1
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
B TR6 Triumph tr6 coolant leak Triumph 4
B Oil (or Coolant) Leak Austin Healey 10
FlyingCat Spitfire Losing Coolant Triumph 12
M TR6 1973 TR6 Coolant Type? Triumph 5
R Coolant temperature gauge Spridgets 8
Govtslug TR6 Coolant Temp Q Triumph 4
T TR2/3/3A TR3 coolant hoses Triumph 2
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
nevets Coolant Temperature Austin Healey 13
L BMC A-series: Oil in coolant British Motor Corp 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
K TR2/3/3A Radiator coolant level? Triumph 5
M TR6 '72 TR6: Oil in Coolant Triumph 25
W TR2/3/3A location of the coolant drains on a tr3a Triumph 4
Got_All_4 Wedge Tapered coolant hose for a PI car. Triumph 3
Paulus TR4/4A Coolant pressure Triumph 5
D TR2/3/3A Coolant tap on TR3 block Triumph 3
gfholl Coolant Leak Spridgets 9
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
S TR2/3/3A Replacement of Engine Coolant Drain Triumph 3
B All the coolant in the wrong place Spridgets 17
G TR4/4A Thoughts on my coolant Triumph 12
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
JFS Wedge Low Coolant Light Triumph 7
PatGalvin TR2/3/3A Coolant System Hoses Slipping Triumph 5
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
Jim_Gruber Replacing Spridget Coolant Spridgets 21
T TR4/4A Coolant in the oil - again. Triumph 18
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
P Coolant level indicator wrong? Jaguar 4
sparkydave Coolant hoses Spridgets 5
T TR4/4A Oh crud - coolant in the oil Triumph 33
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
B TR2/3/3A coolant expelled Triumph 14
Keith_M 1275 burning coolant Spridgets 20
S Coolant Loss Spridgets 32
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
M oil in coolant Austin Healey 16
