G
I towed my MG up to the mountains for storage 10 years ago because the cooling system went out (water pump walked out, fan ground into newly recored radiator). In those 10 years, all of the fluids were left in, including the gas. I thought it would be a simple matter of replacing the water pump, fan and radiator and I wanted to restore it until people pointed out that I hadn't stored it correctly, at all.
What do you think it will take to make it go again?
Are there any tell-tale things I should check out to determine whether the engine is still good?
Where should I look for rust and corrosion?
I appreciate any advice anyone can give me.
Thanks-
jme
Thanks-
jme
