Should I drop the front end down a little?
Healey_Z
and if so what is the best way?
red57
Wow, beautiful bodywork. It is so hard to make black look good, and this really does look good!
If it was me I would lower the front 1/2 inch or so - there are kits available from Denis Welch and others. Basically shims/spacers you place between the spring pans and the a-arms to lower the spring pans & therefore the ride height. If you do lower the spring pans you should raise the rubber bump stops the same ammount. Since the spring pans are about 1/2 way out the length of the a-arms, however much you lower the pans, the ride height will go down about twice as much - 1/4" spacers = approx 1/2" drop in ride height. Good part is no modifications to the car and it's totally reversable.
Just remember there are some negatives. Ground clearance is already marginal and will be worse. Also, lowering the front will make it even harder to see over the top when using the rear view mirror with the top down.
Dave
Keoke
:savewave:
NO!!!---Keoke
John Turney
I dropped mine ~3/4" using the Denis Welch spacers. It looks great, but the driving light mount/front sway bar guards will scrape exiting the driveway unless I back out slowly at an angle.
HEALEYJAG
NO...repeat NO
Pete
no no no NO NO NO nope :cheers:
Johnny
No I wouldn't drop it at all. I'm going to assume you replaced front springs, and rebuilt shocks, so; most likely over time the front will lower a bit.
TimK
It is your car, do what you want. What does it matter what others think. You live with the consequences of your decision!
I think your car is beautiful.
Legal Bill
The car is supposed to look lower in the back and higher in the front. It really is part of the cars look, like it is always under acceleration. I'd leave it be.
H
Healey_Z
It matters to me because I value the opinions of the people on this forum, who are far more knowledgeable on the marque than I am.
Patrick67BJ8
Good point! My two cents. As long as it isn't jacked up in the back like some BJ8's, <span style="text-decoration: underline">it looks good</span>.
I'm going to put earlier 3000 big bore pipes on mine so as not to drag the rear resonators that stock BJ8's have. My leaf springs are new from Jule-Enterprises and are sprung so that car sits level. Hopefully, I shouldn't have much problems and have the "Healey sound" back.
glemon
I don't know what is in the Dennis Welch lowering kit, but I got some longer grade 8 bolts and extra nuts as spacers to lower the front suspension on my 100, no issues in a decade of use.
bob hughes
Personally, I would leave it alone, that sort of thing is for the track IMO. but, what ever you do to it can be altered back if you do not like it.
It is then just a matter of cash being wasted. :wall:
:cheers:
Bob
HealeyRick
Ken,
Standard height from the ground to the center of the front wheel opening is about 27". Your front end probably is a little higher as a result of the lighter Nissan motor. I think it looks just fine the way it is, but if you want to drop it, follow Greg's advice above. Get a couple of lengths of allthread about 10" long and two washers and nuts for each length. Take out two diagonally opposing bolts from the spring pan, insert the allthread in those holes with the nuts on top and bottom. You can then remove the remaining two bolts, unwind the nuts on the allthread until the spring relaxes and remove the spring and spring pan. Reassemble with the longer bolts, using a couple of nuts between the A arm and seat pan to lower it. It takes almost as long to write it as to do it, so it's not to time consuming to do it and see how you like it.
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR6 Should I Buy This "73 Triumph TR6" Triumph 3
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
S Well, this should be interesting..... Other Cars 9
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
C MGB Should I lubricate the cog gears MG 2
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
George Zeck What fuel gauge SHOULD I have? Spridgets 3
B How often should you change the rear rear axle oil Austin Healey 9
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
abarth69 Should I remove this section Spridgets 8
L Should I do it?? [electrical conversion] Austin Healey 24
B TR2/3/3A what adjustment should i select with Koni shocks onTR3? Triumph 4
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
F Exhaust gas analyser - what carbon monoxide level should I expect from my BT7? Austin Healey 7
K TR2/3/3A How long should an SU damper top up last? Triumph 22
M TR2/3/3A What oils, lubes etc should I have at my house at all times? Triumph 39
Got_All_4 TR2/3/3A What color should these parts be? Triumph 4
Joe Reed MGB Wiring problem....this should be fun :[ MG 4
stretchit2 Portable Hardtop Rack - Should it stay or should it go Austin Healey 28
M TR6 Should I buy a TR6? Triumph 24
Keoke Everone should own one Austin Healey 14
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
Wirewheels General Tech Do we really care what our LBC's speedometer reads? Should we? MG 7
S TR6 Worth Saving??? What do you think we should do? Triumph 30
GTP1960 TR2/3/3A Should you paint your leaf springs? Triumph 5
2billydavies TR2/3/3A what bolts should i use to mount engine on an engine stand? Triumph 13
V General TR should or shouldn't? Triumph 19
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
luke44 General TR Every TR Owner should really appreciate this picture. Any guesses? Triumph 7
M TR4/4A Where should TR4A carpet snaps be placed? Triumph 10
J TR4/4A 1965 TR4 in pieces, What should we do with it? Triumph 9
Got_All_4 TR2/3/3A What color should this part be? Triumph 5
JPSmit Bring a Trailer should be banned Other British Cars 3
M How well should the water pump free spin? Spridgets 4
C What should the VIN plate look like for a BN1? Austin Healey 1
N Spitfire Should this be bent? Triumph 4
PatGalvin TR2/3/3A what color should it be...? Triumph 7
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
