Question of the day - More bushings
jlaird
Do the Radius arm bushings come with a metal insert, like a small tube? Can not really tell from the pic.
cdsmith
The bushings (stock "rubber" type) that I recently installed did.... Just for the record I had the shop, where I bought the bushing, press them into the radius arms - and I'm glad I did - I don't think I could have done it myself...
cd
Platinum
Bench vise and some "nobbling" gets 'em in... but a better method is turn it over to a shop with a press. Let THEM have all the fun /ubbthreads/images/graemlins/wink.gif
GB1
I took the easy way out and replaced the arms..
msoylemez
Yes, a press will be best for both the bushings in the arm and the 1/4 springs...I paid my local garage $5 to do this.
Y MGB Answer to a question creates more new questions.... MG 12
R TR2/3/3A One more crank pulley question Triumph 7
K TR2/3/3A One more Steering Box question. Triumph 2
M TR2/3/3A One more steering question TR3 Triumph 4
AngliaGT One More Time - Redline Question Triumph 5
T One more SU HS6 question Triumph 25
T Yet one more bushing question - which to order Spridgets 4
T One more wiring question [and some progress] Triumph 5
JPSmit Oops one more question Spridgets 17
T more progress and a question..... Spridgets 1
B One more Pertronix question Triumph 29
Woodie 1 more question, Spridgets 10
G Question and more pictures Other Cars 8
JPSmit Oops one more, Cooling Question Spridgets 2
S Pertronix one more question Austin Healey 14
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
