POR15 Fuel tank repair kit
ncbugeye
Does anyone have any experience with this, it comes as a 3-part kit to restore the INSIDE of the fuel tank on an old car. What are the things to watch for and/or avoid?
KLUTZ
I used it on the fuel tank for my GT. Haven't gotten to the point of putting gas in it yet, but if you read the instructions and follow them strictly, you are good.
Paul
prb51
As the other guys reported, make sure you remove everything from the tank prior to coating. Failure to do so will cause the coating to fail and the coating material will flake off causing major headaches. High pressure spray and then boil the tank out with the provided cleaner/prep.
tony barnhill
Great Pumpkin - R.I.P
Take the tank to a radiator shop & have them boil it out to make sure its clean.
John Loftus
Hirsch Auto has a gas tank cleaner, etch and coating. It looks like they are the supplier for what Moss sells. I have cleaned and applied it but haven't filled the tank yet.
The Hirsche website has some good information on prepping the tank and sealing (under gas tank repair > gas tank sealer > questions and answers about using this product) but they are pretty harsh on using products that sound like the Por 15 type. I don't know if what they say is true .. only point it out so one can do their own research and make a decision.
https://www.hirschauto.com/
Cheers,
John
prb51
Good advice on the radiator shop boiling the tank out. Any foreign material will ruin the job.
I've had great success with POR products btw. Hard to find any competitor willing to spend advertising space talking up someone else's products. I've heard Hirsch stuff is well liked too.
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
S TR2/3/3A the self of POR15 is and how to apply POR15 Triumph 11
J herculiner over POR15 for underside Restoration & Tools 13
T POR15 and cage nuts Triumph 2
Basil por15 for gas tank Jaguar 12
S Picklex20 and por15 don't mix MG 1
J painting over por15 - advice needed. Restoration & Tools 7
J My two pieces of POR15 advice Restoration & Tools 0
Stewart I hate por15 MG 9
Brosky Frame stripping and POR15 pictures link Triumph 2
Brosky Up-date: Frame stripping and POR15 painting Triumph 30
G Issues with POR15 Triumph 22
A RUST: Eastwood, POR15, KBS or ??? Austin Healey 8
H Painting over POR15 Restoration & Tools 4
T MGA MGA fender removal for POR15 treatment MG 5
C HEALEY GREEN ENGINE ENAMEL-POR15 ??? Austin Healey 33
milemarker60 Powder Coat or POR15 Frame? Triumph 11
Tim Tucker Rust Treatments: Por15 vs Rust Bullet Restoration & Tools 9
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
