Pivot bolt stuck - BFH time?
tdskip
Specifically #92 won't budget even with the pressure relieved from the rotor assembly etc...
Penetrating fluid and BFH time? (I just love writing hammer time. Don't tempt me or I'll break out in song).
HerronScott
I wonder if it's rusted to the distance pieces (93). I don't suppose with the nut off that you can pull 94 and 93 out on that side (or at least tell if the bolt is rusted to that distance piece)?
If you pull the entire suspension off the car altogether after dropping the bottom spring pan and spring, shouldn't you be able to pull the lower forward arm off (90) assuming you can get the plastic/nylon bush (94) off?
Scott
TR3driver
Great Pumpkin - R.I.P
Keep in mind though, that while the bolt & trunnion are disposable, you probably don't want to ruin the A-arms. This might be a good time for an angle grinder & cutoff blade first
Platinum
Slightly different setup BUT(!) I'd recommend the Weasel Pee (50/50 acetone & ATF) penetrant... used it on Her MGB after a LOT of other methods and 'stuff'.
It WORKS!
T
tdskip
Scott
Hi Scott!
I think it most likely is. And per your idea I could pull the remaining suspension off more or less intact if the darn thing won't budge. That will give me better access to everything and, as Randall pointed out, minimize the chance of messing up the A-arms.
D TR6 Rusted Trunnion Pivot Bolt Triumph 18
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
T Anyone have a spare HS6 pivot bolt Triumph 13
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
D For sale. TR3A Bellcrank Pivot and lever. Triumph Classifieds 2
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
eschneider fuel pump lever pivot pin retaining shims? Triumph 3
tomshobby A way to lube the clutch pedal pivot. Triumph 1
vping What size are pivot nuts? MG 14
Lin Smitty Conversion -Throw Out Bearing and Pivot Arm Austin Healey 3
S Clutch Pivot Pin Triumph 4
S Clutch Pivot Pin Triumph 1
JPeter TR2/3/3A TR3 Rear Spring - front pivot - removal Triumph 18
Tosh TR6 TR6 Upper a-arm pivot Triumph 4
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
S TR2/3/3A old 4 bolt axle differential. Triumph 11
KVH General Tech Dog Bolt Torque—Crankshaft Triumph 11
JPSmit A fairly specific looking bolt Spridgets 10
F 59 bugeye spring bushing bolt Spridgets 8
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
R difficult bolt access Spridgets 8
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
B TR4/4A Starter dog bolt Triumph 15
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
W Wanted Bolt on luggage rack Triumph Classifieds 4
maxwedge5281 front hubs for bolt on wheels Austin Healey 7
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
D Oil Filter Bolt Seal Austin Healey 2
C Tough Bolt on front of Crankshaft Spridgets 16
Scotsman TR4/4A Spinners for bolt on minilite wheels Triumph 0
G TR4/4A ARP Bolt Torque Specs Triumph 10
B TR2/3/3A Rear Spring front attachment bolt Triumph 23
Csarneson Connecting Rod Bolt Question Austin Healey 3
maxwedge5281 Wanted want to buy! one bolt on 3000 wheel! Austin Healey Classifieds 2
tomshobby Spitfire head size of damper pulley bolt on 78 Spit? Triumph 2
D BJ 8 Float Bowl securing bolt loose Austin Healey 6
tr3guy TR2/3/3A TR3 Fan Bolt Torque Triumph 3
