TR4/4A Lower Control Arm Front Pivot Bolt
KVH
For a TR4A, if I put a jack under the spring pan, can I remove and replace the pivot bolt holding the control arms together?
I don't like the bolt or the trunnion I now have. I want to replace both. But I don't want to remove the spring and go through all that again.
I suppose that with the spring still in, and with the control arms bolted to the pan, that pivot bolt might be jammed in too tight to slide it out. Or, maybe just slightly loosening the pan fastening bolts would help.
Thoughts? If I just need to remove the spring, I will.
Thanks all.
Popeye
Bronze
Smarter folks than I will chime in... but I don't think you can remove the trunnion without unloading the spring.
CJD
That bolt is actually a long pin pressed into the trunnion. I know of no way to remove it without removing the pan and lower arms. I have ruined 12 ton presses attempting to remove the pin from the trunnion, although the manual implies it should be relatively loose fitting.
JerryVV
On a 4A thru the TR6 that "pin" is a through bolt, not a "pin" as stated above. TR4 back to TR2 it is a "pin".
JerryVV
Jack under the spring pan and lift enough to just lift the car. You should then be able to remove the bolt and the trunnion unless things have corroded together. Assembly is reverse. Shock will keep things together.
KVH
KVH
I just thought of something. There's no engine or transmission in the car. If I jack under the spring pan, will it still work, or leave it all too tight? Maybe I just take that darn spring pan back off after all?
JerryVV
You might try a spring compressor in lieu of the shock to relieve the spring pressure. Without the weight of the engine I doubt that jacking under the spring pan will compress the spring.
TRopic6
Yeah - if you can get the spring pressure under control, you might be able to use the new bolt to push the old one out. That should keep the two A-arms and trunnion in alignment. If bolt-head orientation (or originality) is a factor, you could tap in another new bolt from the other side.
Popeye
Bronze
Spring compressor goes right down the middle of the spring - there is considerable disassembly required to get to it. The frame is not heavy enough to compress the spring... a lot more mass is needed!
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
Tr3aguy TR2/3/3A Lower control arm question Triumph 2
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
sqbsprite TR6 Frame cracking around lower control arm mount, have you checked yours? Triumph 3
Tabcon TR4/4A TR4 Lower Control Arm Bushings Triumph 6
MattP Lower control arm bushings MG 4
1 lower control arm bolts? Austin Healey 6
G Lower control arm bushings Austin Healey 8
RCarr BN1 Lower Control Arms Austin Healey 0
KVH General TR Lower Control Arms Triumph 1
BoyRacer BN1 lower control arms Austin Healey 1
TR4 TR4/4A TR4 Lower Control Arms Triumph 2
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
S TR2/3/3A lower small brass bushing Triumph 13
S TR2/3/3A steel bushings for the lower Arms Triumph 10
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
R TR6 Lower A-arm trunnion bushings Triumph 18
edkap2002 TR6 lower radiator hose fitting Triumph 2
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
B TR2/3/3A lower wishbone installation Triumph 5
L TR2/3/3A Bent lower wishbone arms Triumph 6
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
C TR6 Lower A-arms Triumph 8
wangdango BJ8 lower radiator hose! Austin Healey 2
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
Rut TR4/4A Lower fulcrum brackets Triumph 3
aero3113 100 lower windshield seal Austin Healey 4
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
Jeepster Lower wishbone bush replacement. Austin Healey 33
H Post-War Other Herald rear suspension lower block installation Triumph 3
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
Martinld123 Want to lower car about an inch Austin Healey 4
Rut TR4/4A Lower crash pad Triumph 9
B TR2/3/3A Removing front lower wishbone confusion Triumph 3
M TR4/4A Left lower dash crash pad. Triumph 5
Geo Hahn TR2/3/3A lower generator bolt Triumph 7
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
M TR4/4A Lower crash pads for dash....help. Triumph 4
Keith_M Lower wishbone recondition? Spridgets 5
PAUL161 T-Series Windshield lower rubber MG 5
J TR2/3/3A Lower windshield rubber seal Triumph 3
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
madhouse RF Fender and Lower Cowel Body Parts needed Austin Healey 10
