For a TR4A, if I put a jack under the spring pan, can I remove and replace the pivot bolt holding the control arms together?
I don't like the bolt or the trunnion I now have. I want to replace both. But I don't want to remove the spring and go through all that again.
I suppose that with the spring still in, and with the control arms bolted to the pan, that pivot bolt might be jammed in too tight to slide it out. Or, maybe just slightly loosening the pan fastening bolts would help.
Thoughts? If I just need to remove the spring, I will.
Thanks all.
Thanks all.
