Rocker Pedestal Banjo Bolt Thread Size
Jkirchner
Bronze
Is the thread pitch for the Healey 3000 1/8-28 BSP and if so, do you know what size tap the Heli coil is?
I found a place that has the repair kit for $100 (if this is the correct size thread), and they also have the repair coils but they don't say the thread and pitch of the tap.
I don't want to just buy another pedestal I want to make a more permanent repair.
BobHaskell
is the thread pitch for the Healey 3000 1/8-28 BSP and if so do you know what size tap the Heli coil is I found a place that has the repair kit for $100 (if this is the correct size thread), the also have the repair coils but they dont say the thread and pitch of the tap. I dont want to just buy another pedestal I want to make a more permanent repair.
Yes, the thread is 1/8 BSP. The kit will come with the drill and tap. Uni-Thread Ltd. in the UK list the kit, tap, drill and inserts on their website. Different length inserts are shown. 1D(iameter) is the closest to what you need, but might still need to be trimmed.
Jerry
Thanks for the info. Last time I had a stripped one, I ordered a new pedestal. I even have a tap 1/8BSP
Jkirchner
Jkirchner
Bronze
I have taps and drills I found a company that had the coils for $10 I would prefer not to buy a kit for something I will on use once in a lifetime this is why I was asking what the tap size is for the coil.
BobHaskell
I don't know as I don't have a 1/8" BSP kit, but I'd be surprised if the required tap was a standard size. The tap for the 3/8"-19 BSP insert is 0.727" diameter. Not a standard SAE or metric thread diameter.
BobHaskell
The tap for 1/8" BSP insert has an outside diameter of 0.428". Not a standard size.
I have the Heli-Coil repair kit for the rocker pedestal, and as you can imagine, I still have most of the inserts left (I think I have only used two so far). If you, or anyone here, wanted to send me their pedestal, I'll do the repair for the cost of shipping.
ALWAYS attach the fitting/pipe into the pedestal first...
... THEN attach it to the head!
Last but not least, don't over tighten it ;)
Hi Randy,
I'm gonna go on a tangent here and ask for your take on 'heli-' coil--and all the equivalents on the market--vs. Timesert. The Timesert people, of course, claim superiority, and it looks like they have an argument but, certainly, helicoils are more than adequate for most applications (like this one).
Hi Bob,
For the sake of discussion, we'll call Heli-Coils & Recoils the same thing, so it's them versus Time-Serts. Those being the only types I have at least some exposure to (I know there are wood-workers types, but that's completely foreign to me).
Now I've never used a Time-Sert, and it wasn't until recently that I saw a picture of one of their kits, showing the included counterbore. It makes sense, but I'd previously envisioned it requiring a milling machine setup; but it still seems like a lot of extra work.
I've got a pretty good assortment of Heli-Coils, from 6-32 through 3/8, both fine and coarse pitch, including a LH set for 3/8-16, plus M6 to M14, along with the 1/8-28 BSP to suit the rocker-arm oil-feed (a size that I did not see on the Time-Sert website...).
The point I want to make is, while sometimes a Heli-Coil repair seems like a gamble__that tiny 6-32 to save a Tillotson carburetor comes to mind__I have never had an application that did not work. A couple of times, I suppose I screwed up the installation and had to pull out the insert by unwinding it, those things can be really long when you straighten one out btw, but I've never had a repaired thread fail once it was put back in service. I'm real happy with that.
The next time I need to repair a thread in an aluminum head (preferably a McCulloch and not a BMW) I may give the Time-Sert a try, but their kits, no doubt due to the extra tool/step required, are noticeably more expensive than the Heli-Coil/Recoil brands.
Thanks, Randy, my take too. Helicoils are perfectly adequate most of the time, but I think Timesert might be a bit stronger, and don't have the 'rough edge' of a Helicoil end. I usually, unless I forget, put red threadlocker on the install,
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
CJD TR2/3/3A Rocker Pedestal Triumph 9
M Rocker pedestal stuck...! Austin Healey 7
M Bajo bolt and rocker pedestal threads.. Austin Healey 6
texas_bugeye Rocker pedestal Height Spridgets 9
G Torquing rocker pedestal changed clearances Triumph 1
Tinkerman 60 TR 3 post 60000 Rocker Shaft Pedestal Bushings Triumph 2
Lin threaded rocker pedestal Austin Healey 5
B Rocker Pedestal Shims MG 1
kch Rocker pedestal - oil feed threads ? Austin Healey 13
R Rocker Pedestal Problem Austin Healey 2
Mickey Richaud Rocker Pedestal Shims MG 14
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
WHT Rocker Arm Shaft Replacement Austin Healey 21
G Installing New Rocker Shaft Assembly Austin Healey 3
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
Hamish Racing General TR Rocker cover identification please. Triumph 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
H Rocker Cover Data Plate Austin Healey 15
Twit TR4/4A 1.5 in outside diameter rocker cover pipe Triumph 3
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
M Rocker feed kit for 1500 from Victoria British Spridgets 0
Jim_Stevens For Sale New Rocker panels TR3A Triumph Classifieds 1
P TR6 Rocker panel hole Triumph 16
D MGB MGB rocker shaft shims MG 1
Lukens Outer rocker showing "rust" Restoration & Tools 11
Joe_Healey 100 Chrome Rocker cover and air cleaner option Austin Healey 0
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
D rocker arm assembly Austin Healey 14
Rut Replacing rocker assembly Spridgets 1
JimLaney Rocker shaft plug/screw delima Spridgets 3
J TR4/4A New Rocker panels [sills] not round enough Triumph 10
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
P Rocker Cover Vent Spridgets 22
matmire rocker arm stress cracks? advice please. Spridgets 2
red57 Outer Sill/Rocker fit problem Austin Healey 11
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
M TR6 rocker shaft install tr6 Triumph 2
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
KVH TR4/4A Rocker Shaft Lubrication, and Issue with Push Rods Triumph 1
S TR2/3/3A rocker covers again Triumph 13
M TR2/3/3A Rocker cover question Triumph 11
S MGB-GT Wanted: REMCO MG Rocker/Valve Cover MG 0
S TR2/3/3A rocker cover panels for the pre60K tr3 Triumph 1
S A few valve cover [rocker cover] related questions, 3000, BJ8. Austin Healey 9
