Since I have a fake roll bar, the one I adapted a windblocker and 3rd brake lite to, and now that EVERYTHING is removed from the rear...wonder if I can reinforce the faux bar to the frame and approach the strength of a real one. Underneath the body, the multiple bolts that affix the fake bar to the body are readily visible, and so is the frame beneath. Wonder if I could add a bridge to the bottom of this bar and weld or bolt this to the frame, straddling the coil spring tower. If ya'll don't quite envision this, then do as I have done and remove everything in the rear and you can see quite well. Don't want to add too much weight or make it too complicated, but I think this would greatly enhance the strength of the faux bar.
Just thinking.
Just thinking.
