67 Etype, 82,000 mi. On startup it stumbles really bad even with starting ether, after much throttle jiggling can get all 6 to fire. After a drive it starts immediately, then next day same old routine. After about 30 secs of stumble, rear three "header" stubs warm to touch, front three COLD. Fearing valve guide leaking, take out plugs, no oil visible, clean plugs anyway, still stumble till magic process of throttle massaging gets it to go, float chambers about 3/4 full, about to do from beginning carb set-up, any other thoughts? Can not imagine ignition cause so have not checked for spark during stumble period--will do so. There is a blast of smoke from exhaust for about 5 secs once all cylinders firing. Jay, (OfflineJ@aol.com)
