TR2/3/3A Hard starting when hot
TR3sharon
Member
I've been sorting out a fuel issue with my TR. After swapping in a new tank, I'm frequently change fuel filters because I foolishly didn't change the lines while I had it torn down. Now that I think most of the gunk has run out, the car is refusing to refire when it's hot unless I push start. Starts great when cold. Related to the fuel or new issue like say, timing?
TR3driver
Great Pumpkin - R.I.P
You say it will start when you push it? Sounds like an ignition problem, related to the battery voltage drooping while cranking.
Or what a lot of people (myself included) have experienced is the fuel boiling in the float bowls and jets, pushing fuel out into the intake manifold and causing a very rich condition. This typically shows up after driving fairly hard (like uphill or freeway speeds) followed by immediately shutting the engine off for 5 to 20 minutes or so. On a club run a few miles back, after we stopped for a "biology break" in the mountains, there were quite a few of us that almost couldn't get them started again. I can't explain why, but it seems to have gotten much worse with ethanol in the fuel.
In my case, adding a heat shield under the carbs made a big improvement, although it still runs a little rough at first under those conditions.
Another thing that seems to help is to follow the book suggestion and hold the throttle partway down while cranking when hot. I think it helps move more air through the carbs & manifold, to clear out the excess fuel.
Here's a shot of the heat shield as I was installing it.
Bob_Muzio
Have you considered a coil? If you have a spare swap it out just for a try.
Bob
T
TR3sharon
Member
Updated: Battery was the winner! Thanks for the help
The coil is only a few years old, limited mileage. Now the battery, a whole other story. I imagine fresh plugs wouldn't hurt either.
That is one slick looking heat shield.
TR3driver
Moot point now, but I had a new Lucas coil fail within about 10 months of installation. You just can't trust "new" parts to always be good!
Just got done changing the water pump on my TR3. Apparently, the "high tech" pump I put on last year must've been leaking just a little bit from the very start. Since it had no weep hole, the bearings filled with water and eventually seized; whereupon the shaft started turning inside the bearing races! Just incredible that I never noticed any bad noises, or belt slipping, etc. The shaft is now a good 1/8" undersize, from wearing against the inner bearing races, and of course incredibly sloppy once the fan belt was removed.
T
TR3sharon
Member
It wasn't one of those 6 blade pumps from Moss? Mine's making a racket since I swapped to it.
TR3driver
May be the same pump, but I got mine from BFE a long time ago; before Moss started offering them.
PeterK
Check the pump for signs of rubbing from the pulley. Mine needed a little grinding on the housing to quiet down.
T
TR3sharon
Member
I clearanced it prior to fitting. I'll double check just for peace of mind however
S 57 T-Bird hard starting when hot Other Cars 5
W hard starting when hot MG 7
S TR2/3/3A TR3 Hard Starting Triumph 4
D Hard Starting Austin Healey 14
R winter hard starting BJ7 Austin Healey 16
P TR6 TR6 hard starting Triumph 24
S Hard starting on Webers from cold Austin Healey 12
P TR6 Follow-up to hard starting Triumph 4
P TR6 hard starting Triumph 23
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
R hard starting Austin Healey 8
B Hard starting 1960 AH 3000 BT-7 Austin Healey 6
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
S BJ8 hard starting when warmed up Austin Healey 11
J Spitfire 78 Spitfire hard starting Triumph 2
Thor Suggestions for hard starting 1500 when cold Spridgets 5
roofman Spitfire Hard starting Spitfire Triumph 12
Stewart Backfiring stalling and missing hard starting MG 5
D MGA MGA hard starting sometime backfires MG 2
E hard starting-engine quits Spridgets 14
R Hard starting problem Austin Healey 2
W Hard starting Jaguar 5
W Hard starting in the cold Austin Healey 4
txtr3 TR2/3/3A TR3 hard starting, but has been running ok Triumph 11
G Hard starting, but then runs fine MG 6
J Hard Starting vs Fuel Austin Healey 3
L T-Series Hard to start MG 11
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
E Spitfire '69 Spitfire hard top Triumph 2
T TR2/3/3A A type overdrive hard engagement Triumph 36
7 Top, hard Triumph 0
KVH TR4/4A Hard Start When Engine Hot Triumph 20
roscoe New / old hard top Austin Healey 16
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
B TR2/3/3A Hard Top Part Triumph 2
B TR2/3/3A TR3 Hard Top Triumph 2
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
Basil Spitfire Hard Top Seal Triumph 5
Madflyer MG B hard top MG Classifieds 0
Sopwith_Camel hard top bracket happy day Spridgets 4
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
K TR2/3/3A Hard start questions.... Triumph 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
Lin Brake hard line question Austin Healey 4
A BN4 Hard Top Austin Healey 23
