Jim Weatherford
Dave;
Excellent treatise...
In California we are victims of the Smog Police more than possible any state in the US. I have solved the problem from my prospective at least. We are blessed to be able to drive pretty much year round here in Southern California, so “Wake-Up” isn’t as much a concern, but the fuel companies are constantly messing with the formulations, I suspect to use less actual petroleum distillates and add more additives and alcohol. Well performance is a noticeable problem. Being that I can’t afford $8.00 per gallon racing or aviation fuels on a regular basis, I make my own.
I’m not a chemist, more like a Mad Scientist, I read lots of arcane data sheets and MDS (Materials Data Sheets) Forms and have come up with my answer to the fuel problem. First I fill the Jensen Healey fuel tank, then I add 10 ozs. of Toluene (Toluene occurs naturally in crude oil fuels (including gasoline) and in the tolu tree. Toluene is produced during the process of making gasoline and other fuels from crude oil, in making coke from coal and as a by-product of styrene. Toluene is used in the production of nylon, plastic soda bottles and other organic chemicals. It is also used in making paints, paint thinners, fingernail polish, lacquers, adhesives, and rubber in some printing and leather tanning processes.) They (the oil companies) take it out of the mix and I add it back in to the finished product, don’t tell the Smog Police on this either. I also add an ounce of Automatic Transmission Fluid (ATF) per tank as a cleaning agent and BINGO!!! 105 octane gas available on a regular basis at a much lower cost per gallon.
I have been using this formula for years and it has shown no ill effects, recently I pulled the heads on my Dodge 318 CID engine in my Jeep Gran Cherokee with 198,000 miles on it to correct a head gasket leak, my co-worker and I was amazed at the condition of the engine, I even pulled the pan to check the condition of the lower end and it was clean and within tolerances. Not too bad for such a high mileage engine.
So you can do as I did or not, it’s after all it is a homemade “Witches Brew”, but if you read the bottles of octane boosters and engine cleaners, more importantly the MSD sheets you’ll see why this works and why I like it.
Be WARNED… Toluene is a highly volatile chemical, it will burn and it will explode, if not handled properly and carefully, use gloves and face shield when mixing. I only keep 1 gallon at a time in a tightly sealed canister and I keep it in my fire proof cabinet. Once mixed, it is very stable and as safe as regular high octane gasoline. Be careful and have fun. Good luck.
