Thanks for the input, but I am still confused. I have a 69 TR6. When I took apart the outer metal rings on the tach and speedometer some black crumbly material (what was left of it anyway) fell out. Now at least I know what that is - thanks. In addition to this material, on the other side of the glass was a thin paper gasket (at least for the tach and speedometer). The smaller gauges were similar, except that there was no paper gasket on the other side of the glass. Between each gauge and the wooden dash was a typical O-ring. Based on the two posts above, I am still confused. I am going to put the o-rings between the gauges and dash like before. I was going to put the square type o-ring on between the outer ring and the glass and glue it in place first with black silicon. On the two larger gauges I will put the paper gasket back between the glass and gauge body. Won't this arrangement seal off my gauges? Although I keep my car garaged, moisture is a big factor where I live. I get condensation inside the gauges. I am hoping putting in new seals will stop this. Any other suggestions?
Thanks, Kevin
