Fuel pump fuses
RobG
My 1976 XJ6-C fuel pump on the left side is out, and I can't find the fuse in the fuse box. Does the 1976 XJ series have an inline fuse hidden somewhere? I've checked the trunk (sorry, boot) but no luck. Any advice appreciated, thanks.
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
sundown TR6 Fuel pump Triumph 10
