Front Suspension Question with Pic
Miser
I am rebuilding my front suspension and I was wondering if the red polyurethane bushing(on the left)can replace the gray nylon bushing (on the right)when I install the bolt that connects the wishbone arms to the wheel assembly? The red one is bigger so it will be a tight fit if I do replace the gray one with it.
M_Pied_Lourd
Just wondering if that is the bushing for the upper fulcrum?
Cheers,
M. Pied Lourd
M
Miser
Cheers,
M. Pied Lourd
It is and I used them for that but I have four left enough for the bottom one on both sides and I'm not sure if I can use them.
M_Pied_Lourd
I don't think so off the top of my head.
Cheers,
M. Pied Lourd
Platinum
On the bottom of the fulcrum pin you want stability, the nylon is what should be there. Very like the MGB, poly is fine for the inboard attachment of the a-arms but at the kingpin pivot you need a bushing, not compliant material. :thumbsup:
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
D Front suspension question Austin Healey 0
C TR2/3/3A Question on assembly of front suspension Triumph 3
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
TR4v8 TR4/4A tr4 front suspension question Triumph 2
JFeher TR2/3/3A TR3A Front Suspension question Triumph 3
ekamm Tr 3 front suspension parts question Triumph 7
R TR6 Front TR6 Suspension Question... Triumph 7
G Front Suspension Bushings Question MG 3
K TR2/3/3A TR3 Front suspension rebuild question...... Triumph 5
T TR6 TR6 front suspension re-bushing question Triumph 18
K TR2/3/3A Another TR3 Front Suspension Rebuild Question Triumph 5
J Late BJ8 front suspension question Austin Healey 18
T TR2/3/3A TR3 question - front suspension rebuild access Triumph 7
M TR4/4A TR 4A Front Suspension Question Triumph 2
PeterK TR2/3/3A TR3-4 Front suspension question Triumph 7
SCguy TR4/4A TR4 front suspension question Triumph 8
Wana Front suspension & steering question Austin Healey 4
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
R TR6 Front suspension fulcrum pins Triumph 6
Upland Mark IV front suspension Spridgets 3
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
F TR4/4A Front Suspension Triumph 3
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
D back to the front suspension Austin Healey 4
D Front suspension half moon cotters Austin Healey 6
D front suspension Austin Healey 7
S TR4/4A TR4 front and rear suspension Triumph 8
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
M TR4/4A Front suspension Triumph 4
I TR6 Broken front suspension bracket Triumph 3
Scotsman TR4/4A Front Suspension Strengthening Kit assembly Triumph 2
mcmillal TR4/4A Front Suspension Re-assembly Triumph 7
K TR2/3/3A Greasing the the Idler lever on front suspension? Triumph 3
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
