TR4/4A TR4 front and rear suspension
Sumton
i have an early TR4. i need to replace the front shocks and the rear lever shocks. it looks like the front shocks just unbolt? is it as easy as it looks? i'm assuming you don't have to tear into the front suspension to do this?
on the rear, i've got panhard bars; they are welded in. i'm assuming those will have to come out as well??? anyone have any idea? again, i think it will all unbolt. looks like one of those adventures where i won't know until i go there.
3798j
... is it as easy as it looks? i'm assuming you don't have to tear into the front suspension to do this?
It is...and you don't.
As for removing your lever shocks, how about a photo of your panhard rod.
Foura
Those are not Panhard rods, they are radius rods or tramp bars. A Panhard rod runs across the car and is fixed to the axle at one end and to the chassis on the other end. It locates the axle laterally. The ones that you have are meant to prevent spring wind up under hard acceleration. Unless you have a V8 fitted, this is not a problem that most TRs have. They can sometimes cause peculiar handling at the limit as they move through a slightly different arc compared with the spring. However, it does not look like they will cause you difficulty in disconnecting the shocks.
S
Sumton
thank you! i kind of thought they were overkill for that car. but i think they are period accessories so they will stay.
CJD
Kinda' cool, though! From what I see the shocks will come out without messing with the extra links.
For the front, you need to keep the weight on the front suspension. Then you can remove the rebound stops from the frame (2 long bolts), and then the bottom of the shock is held to a mount with 4 nuts. The mount and bottom of the shock, with the rebound bumper attached to it, can be brought down out of the resulting hole in the spring pan. Of course the top of the shock has a single nut holding it to the tower.
S
Sumton
thank you. last night i made a lot of progress on the front drivers side shock. most of it came off pretty easily. hope to make more progress today.
H TR4/4A TR4 front plate seal Triumph 6
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
M TR4/4A TR4 front coil springs Triumph 0
M TR4/4A Front Bumper for TR4 Wanted. Triumph 3
doughairfield TR4/4A TR4 Front sway bar install question Triumph 9
TR4v8 TR4/4A tr4 front suspension question Triumph 2
Burrell22 TR4/4A Tr4 front end help. Triumph 10
9 Spitfire Spitfire front clip on a TR4 Triumph 17
KVH TR4/4A TR4 Front Sealing Block Triumph 2
S TR4/4A TR4 front suspension shimmy and shake Triumph 8
nissanite TR4/4A TR4-A Front grill ... How did you restore yours? Triumph 5
Tabcon TR4/4A Help with front input shaft seal on TR4 tranny. Triumph 3
K TR4/4A Paging TR4 nut....re front suspension Triumph 2
M TR4/4A Wanted - TR4 Front Fenders Triumph 9
M TR4/4A TR4 Front Suspension Rebuild Triumph 6
SCguy TR6 TR6 front sway bar on a TR4 Triumph 1
T TR4/4A Moss TR4/5/6 front fender patch question Triumph 2
pa297pass TR4/4A TR4 Upper and Lower Front Valance Panel Triumph 6
SCguy TR4/4A TR4 front end alignment Triumph 2
SCguy TR4/4A Early TR4 Front Bumper Brackets? Triumph 1
T TR4/4A TR4 Front Wheel Bearing Triumph 8
T TR4/4A Early TR4 Front Bumper Overriders Triumph 4
Kirk_Fisher TR4/4A TR4 front fenders/engine bay Triumph 13
J TR4/4A TR4 Front Spoiler Triumph 6
T TR4/4A Early TR4 - Front Suspension Trunnions Triumph 7
T TR4/4A Early TR4 - Front Brake Calipers Triumph 2
T TR4/4A Early TR4 - Front Brakes Triumph 3
T TR4/4A what is the ideal front roll center-tr4 Triumph 0
T what is ideal front roll center- tr4 Racing 6
SCguy TR4/4A TR4 front suspension question Triumph 8
TR4nut TR4/4A TR4 front end rebuild - trunnion bushing question Triumph 3
TR4nut TR4/4A TR4 front suspension rebuild advice Triumph 13
TRMark TR4/4A Lowering front of TR4 Triumph 5
mondialo64 TR4/4A TR4 vs 4A front springs Triumph 4
P Wanted WTB Restorable TR4 Triumph Classifieds 2
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 Parts - Rebuilt trans, floors, 4x good 15" painted wire wheels Triumph Classifieds 9
J Wanted- Late TR4 seats or seat frames Triumph Classifieds 0
D TR4/4A Automatic transmission in a TR4 A Triumph 11
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
Twit TR4/4A early tr4 check straps Triumph 4
Twit TR4/4A restoring TR4 sun visors Triumph 0
glemon TR4/4A Wheeler Dealers TR4 Triumph 8
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
Rut TR4/4A TR4 in Longmont, CO Triumph 2
