TR2/3/3A Another TR3 Front Suspension Rebuild Question
karls59tr
Are there any difficulties to removing and installing the lower arms from the spring pan or is it fairly straight forward? Floor jack is under the pan and coil spring compressor is in place. It's amazing how well preserved everything is down there....leaky engines have their benefits it seems. Karl
TR3driver
Great Pumpkin - R.I.P
Removing the arms is easy enough, IF you have the special spring compressor that clamps the spring pan to the shock tower. I wouldn't try it with the garden variety "One size fits none" compressors.
Compress the spring until the pan is roughly level, then undo the various nuts & bolts that hold the arms to the pan. Lower the pan (by unscrewing the compressor), pushing the arms up so the lower arms stay roughly level. When the pan touches the frame, you'll need to pull or lever it away from the frame, then continue undoing the compressor.
Once the spring is fully extended, remove compressor, spring and pan. Now (if you just want the lower arms off) you can undo the nuts holding the arms to the pins, and tap the arms off leaving the vertical link and upper arms in place. But if you plan removing the upper arms as well, I'd suggest doing them and the VL before the lower arms.
Tinkerman
I agree. That is the way to do it. Remember safty first, those springs are powerful and can hurt you in a minute.
Tinkerman
K
karls59tr
I wasnt planning on removing the coil spring or spring pan as I basically want to replace the trunnion and lower bushings and possibly the upper bushings. The shock absorber is still in place.I have the coil spring secured with a set of strut compressor clamps(iron clamps with steel pins that secure it to the spring) and two 5" Grade 8 bolts on the outside of the coil spring. The floor jack is underneath the spring pan.Can I not remove the lower arms and trunnion using this set up.
TR4nut
Karl-
I wouldn't, and I don't think it will work anyway. On the arms closest to the frame and inner pivot point I think they used studs, not bolts- so holding the pan up with the spring won't let you get the arms out. Even without that though, the arms may not be easy to pull off the trunnion/inner pivots. And with what you are pulling apart I don't think you are saving effort but you are probably adding to the effort by keeping the spring compressed. The compressor Randall mentions is pretty easy to make up from hardware parts - worked great when I did it.
Randy.
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
T TR2/3/3A having no shame I ask another question about a TR3 engine that is giving me fits Triumph 10
Got_All_4 TR2/3/3A Another TR3 barn find Triumph 4
T TR2/3/3A Another TR3 battery box replaced Triumph 5
M TR2/3/3A Another rough running TR3 Triumph 1
GBRandy TR2/3/3A Another TR3 prospect - TR3B Triumph 27
T TR2/3/3A yet another TR3 steering box question/hone? Triumph 9
Tinkerman TR2/3/3A Another Steering Box Question TR3 Triumph 4
tinman58 TR2/3/3A Another TR3 gas tank ? Triumph 3
TR4nut TR2/3/3A Another TR3 trans trivia question.. Triumph 2
YankeeTR TR2/3/3A Another TR3 hunt is on....UPDATE!!! Triumph 41
RedTR3 TR2/3/3A Another TR3 Brake Question Triumph 1
S TR2/3/3A My wife is going to freak! Another TR3 coming home Triumph 22
M TR2/3/3A Yet another TR3 question... Triumph 3
gsalt57tr3 TR2/3/3A another obscure TR3 part needed Triumph 7
jsneddon TR2/3/3A Another TR3 comes back to life! Triumph 6
nichola TR6 Another TR6 back on the road Triumph 1
Sherlock Another cruise night, more interesting British iron Spotted 2
D TR2/3/3A Another Carb question. Triumph 22
Healey Nut Another Use for J-B Weld Austin Healey 5
D TR2/3/3A Have exchanged one leak for another. Triumph 9
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
D TR2/3/3A Another mystery part..or two Triumph 14
John Turney Another Article to Criticize Austin Healey 5
tr6nitjulius TR6 TR6 made another list! Triumph 5
Lin Another Trafficator/Control Head Question Austin Healey 10
Rob Glasgow Can I find Another one as Good? Austin Healey 4
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Editor_Reid Bought Another One Austin Healey 14
tr6nitjulius General TR Triumphest 2019 another one bites the dust! Triumph 2
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
Bob Claffie Spotted another AH Spotted 0
SherpaPilot TR6 Just Another TR6 Column Question Triumph 0
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
jackq Another building full of cars available. Other Cars 0
Lin Another trafficator issue Austin Healey 8
B Another OD question Austin Healey 32
Elva164 Finally did another onboard video! Racing 4
Sarastro TR4/4A Another milestone: first engine start Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
Y MGB Another question - this time on seatbelts.... MG 2
PC another one bites the dust... Restoration & Tools 0
AngliaGT Another MGB Spotted 0
J Another Healey back on the road....for now. Austin Healey 8
D TR6 Another Newb Question Triumph 10
D Another use for a leaf blower. Restoration & Tools 1
C Another leak, another question... Austin Healey 20
K TR2/3/3A Another Steering Question... Triumph 17
