Compression check question for '72 Triumph
2wrench
What kind(s) of compressions should I be hoping to
see in a used '72 Triumph engine?
If the compression numbers are okay, I might just go
for buying a used running engine (and grabbing the overdrive
tranny in the deal) and hoping for the best.
Overview is this: Do not have the cash for a new engine.
Hope this will carry me long enough to build yet another
engine, over time.
I would prefer to buy new.....just don't have $5,000
laying around to do so.
Wish me luck. I'm checking the car/engine/tranny
tommorrow morning.
TexasKnucklehead
The numbers will depend on a lot of things. You need to be sure to use the same method to measure each cylinder, and the numbers you read should be within 5 or 10 lbs of each other across all cylinders.
Good luck.
Martinld123 Compression check 1956 BN2 Austin Healey 7
lbc_newbie compression check on uninstalled engine? How? Spridgets 2
wkilleffer Curious about compression check results MG 5
wkilleffer Latest compression check numbers MG 6
P Compression check Triumph 14
RocknTommy compression check on a 1500 Spridgets 3
B TR4/4A Finding compression stroke Triumph 7
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY Compression test results Austin Healey 17
S TR2/3/3A Compression Triumph 8
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 8
NutmegCT Variable compression? Other Cars 22
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
R TR2/3/3A Good Compression Triumph 1
3798j Fastronix Battery Compression Ends Restoration & Tools 4
F TR2/3/3A Compression Test Triumph 13
K TR2/3/3A Compression testing again... Triumph 4
HighAltitudeTR3 TR2/3/3A Compression Question Triumph 10
warwick-steve High compression head identification Austin Healey 16
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
Jim_Gruber Bugsy IV and Engine Compression :[ Spridgets 11
2 TR2/3/3A compression numbers Triumph 1
P TR6 Latest compression test Triumph 11
MY66AH Compression woes Spridgets 11
S Unexpected Compression Readings Austin Healey 14
Gliderman8 TR6 Compression help in one cylinder Triumph 7
tinman58 TR2/3/3A Surprise on compression. Triumph 9
K TR2/3/3A Cylinder Head and Compression Ratio Triumph 0
T TR6 TR6 compression test Triumph 12
B TR6 Fuel tank to line compression fitting Triumph 1
tinman58 TR5/TR250 Compression # Triumph 9
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
M Compression test results Austin Healey 11
R TR2/3/3A Steering, stator tube compression sleeve? Triumph 4
Kleykamp TR2/3/3A compression numbers & smoking engine Triumph 20
S Bugeye 948cc Compression Spridgets 7
L 1275 Compression, Camshaft, et al Spridgets 16
me61ic Compression results - Worth Rebuiding? Austin Healey 13
D Compression #'s Triumph 13
Tinkerman TR2/3/3A 60 TR3A Compression test Triumph 15
D Austin Healey 100-6 Compression Austin Healey 1
P TR6 1971 TR6 compression Triumph 2
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
T Milling a head on a Stock 1275 for compression? Spridgets 13
RichBall For us 1500 guys, high compression head up on Ebay Spridgets 10
M TR4/4A TR4 Optimal Compression - 91 Octane Pump Gas Triumph 13
pkmh Compression Test Results for BJ8 Austin Healey 14
TulsaFred 1275 compression ratios and horsepower Spridgets 29
R TR4/4A TR4a engine compression Triumph 6
