compression check on uninstalled engine? How?
Jim_Gruber
Use a car battery, jumper cables, Google Leak Down Tester. You can make one for $25-30. Gauge $10 or so at HF or was it Pep Boys. One of those. Need a few more parts and pieces.
Westfield_XI
Short of pulling the plugs and hooking up the starter to some jumper cables, you are left with the leak-down test that your mechanic performed on your old engine. Have the seller put this engine in the back of a pick-up and take it to a good shop. They can hook it up in the bed of the truck to the air system in a few minutes and tell you if there are any problems. In an earlier post you said your mechanic told you it leaked at the intake, breather and the exhaust, is that correct? If so then your old engine needs valves as well as rings. I am surprised that the PO would spend to install a 210 gearbox into a car with a bad cylinder, are you sure that they did a leakdown check or did they just do a standard "crank it and pump it" type pressure test.
The leakdown test is much more useful for diagnosis since it uses an external air source to pressurize the cylinder, this allows you to listen at the carbs, the tailpipe, the valve cover and the breather for hissing air. This will not give you a maximum psi of each cylinder, but will show the difference between the supply air pressure and the pressure the cylinder will maintain. To make it easy to compare from engine to engine most people use 100psi as the supply pressure: a good race engine should hold 97% or 97psi, an elderly street engine can get down around 75% and still run smoothly albeit down on power.
Martinld123 Compression check 1956 BN2 Austin Healey 7
wkilleffer Curious about compression check results MG 5
wkilleffer Latest compression check numbers MG 6
2wrench Compression check question for '72 Triumph Triumph 1
P Compression check Triumph 14
RocknTommy compression check on a 1500 Spridgets 3
B TR4/4A Finding compression stroke Triumph 7
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY Compression test results Austin Healey 17
S TR2/3/3A Compression Triumph 8
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 8
NutmegCT Variable compression? Other Cars 22
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
R TR2/3/3A Good Compression Triumph 1
3798j Fastronix Battery Compression Ends Restoration & Tools 4
F TR2/3/3A Compression Test Triumph 13
K TR2/3/3A Compression testing again... Triumph 4
HighAltitudeTR3 TR2/3/3A Compression Question Triumph 10
warwick-steve High compression head identification Austin Healey 16
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
Jim_Gruber Bugsy IV and Engine Compression :[ Spridgets 11
2 TR2/3/3A compression numbers Triumph 1
P TR6 Latest compression test Triumph 11
MY66AH Compression woes Spridgets 11
S Unexpected Compression Readings Austin Healey 14
Gliderman8 TR6 Compression help in one cylinder Triumph 7
tinman58 TR2/3/3A Surprise on compression. Triumph 9
K TR2/3/3A Cylinder Head and Compression Ratio Triumph 0
T TR6 TR6 compression test Triumph 12
B TR6 Fuel tank to line compression fitting Triumph 1
tinman58 TR5/TR250 Compression # Triumph 9
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
M Compression test results Austin Healey 11
R TR2/3/3A Steering, stator tube compression sleeve? Triumph 4
Kleykamp TR2/3/3A compression numbers & smoking engine Triumph 20
S Bugeye 948cc Compression Spridgets 7
L 1275 Compression, Camshaft, et al Spridgets 16
me61ic Compression results - Worth Rebuiding? Austin Healey 13
D Compression #'s Triumph 13
Tinkerman TR2/3/3A 60 TR3A Compression test Triumph 15
D Austin Healey 100-6 Compression Austin Healey 1
P TR6 1971 TR6 compression Triumph 2
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
T Milling a head on a Stock 1275 for compression? Spridgets 13
RichBall For us 1500 guys, high compression head up on Ebay Spridgets 10
M TR4/4A TR4 Optimal Compression - 91 Octane Pump Gas Triumph 13
pkmh Compression Test Results for BJ8 Austin Healey 14
TulsaFred 1275 compression ratios and horsepower Spridgets 29
R TR4/4A TR4a engine compression Triumph 6
