Compression #'s
davjac889
I did a compression check on my tr3a:
#1-120lbs., #2-120lbs., #3-58lbs., #4-90lbs.
What can I deduce from these numbers.
The car runs great by the way.
sd80mac7204
#1 and #2 are healthy... #3 is sick and #4 is not so great.... Depending on how you performed the test.
Geo Hahn
A leak down test will get more specific about where you are losing compression (e.g. valves, rings, head gasket).
You can do another compression test with a spoonful of oil dumped in the cylinder --if that markedly improves things then suspect the rings.
Have you adjusted the valves lately?
bobhustead
Did you use a "screw it into the plug hole" gauge and hold the throttles full open during the test. The rubber bushed "hold it in the hole" gauges are not very good. As far out as 3 is, if your test is accurate, it should be running like crap. As George says, a shot of oil will seal the rings for the comp. test.
Bob
davjac889
Thanks all.
The compression tester is
the screw in variety. The engine
wasn't completely warmed up and I did put some oil
in the low compression cylinder without
much improvement.
I didn't have the engine running during the test.
And like I said, it runs spectacularly. I decided to see where a 54 year
old engine stood after years of abuse.
I've not adjusted the valves but maybe I'll look into it.
Again thanks all.
sail
You would want to turn the engine over the same number of times for each cylinder, 5 or so should do it.
Absolutely adjust the valves.
glemon
I am not surprised that it still runs good, the TR 4 cylinder is a good motor, I had times when mine lost spark in one cylinder and still pulled strong, ran pretty rough, but not so bad as you might expect. Ditto on the adjust the valves, if that doesn't fix things you are probably due for a rebuild at some point, but they can often run on and on even when severely worn, my old 4A was burning about a quart for every tank of gas before I rebuilt it, and still ran pretty well (but ran even better after the rebuild).
Lukens
All plugs out or leaving the remaining three in during test? There seems to be a lot of differing opinions on this. I've always taken all the plugs out. Can't see how leaving the other three in can influence compression. It's also a lot easier to spin the motor with all out.
FWIW All my cyclinders are 150 -155.
TR3driver
Great Pumpkin - R.I.P
Leaving the other plugs in will slow down the starter motor; it turns much faster with only one cylinder coming up on compression than with all 4 doing so. And when you read low compression, you are basically comparing how fast the piston is compressing the air to how fast the air leaks back out of the cylinder. Any change in cranking speed will make a difference when you are looking at a bad cylinder.
That said, as long as the method you use is consistent from cylinder to cylinder, and all you are doing is comparing the relative readings (which is all you should look at), then the exact method, gauge, etc. is not so important. Personally, I always take all the plugs out; but I have never seen any difference at all with the throttle(s) closed or open, so I just leave them alone. I also don't worry about trying to count revolutions, just keep spinning it until the reading doesn't change.
The squirt of oil is a valid test, but note that the pressure will always come up some. What you are looking for is a big change in reading, which implies the air was going past the rings. The oil will temporarily plug up the leak in the rings and hence you'll get closer to a normal compression reading.
With my compression gauge (which is the screw-in type), it is easy to unscrew the hose from the gauge and put an air fitting on the hose. I also have to remove the Schrader valve core from the piece that screws into the engine. Then I can use air pressure to pressurize the cylinder and listen for where the air is escaping. If the hissing is loudest in the exhaust, that means a bad exhaust valve. Loudest in the rocker cover indicates bad rings (or bad cylinder wall, broken rings, broken piston, etc). And you can listen in the adjacent cylinder (#4 in this case) to see if you are actually looking at a blown head gasket (which would be my first guess from those numbers). This is essentially the same test as with a leak-down tester (but without having to buy the tester).
Lukens
Here is a good explanation of how to adjust the valves: https://www.macysgarage.com/myweb6/valve_adjustment.htm
It is a pretty simple to do and won't take long once you understand it.
Good article. The cam dwell on the "closed valve (rule of nine)" is well ove 180 degrees. No need to be too precise on locating exact cam position. As long as the compliment of 9 is"visibly" open , you can be sure the other valve is closed. I don't turn the engine over by rotating the fan blades. Just bump the starter solenoid a couple of times from under the hood... bonnet.
Geo Hahn
...With my compression gauge (which is the screw-in type), it is easy to unscrew the hose from the gauge and put an air fitting on the hose. I also have to remove the Schrader valve core from the piece that screws into the engine. Then I can use air pressure to pressurize the cylinder and listen for where the air is escaping...
It case it isn't obvious, you probably want to do this with the subject cylinder at TDC on the compreesion stroke so both valves are closed. Also have the gearbox in gear and the handbrake set.
I once did this to confirm a blown headgasket. Set up as described and streched a latex product from Walgreens over the neck of the radiator (a rubber glove would work too). When I applied the air pessure to the cylinder the 'balloon' inflated. Quite a sight.
B TR4/4A Finding compression stroke Triumph 7
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY Compression test results Austin Healey 17
S TR2/3/3A Compression Triumph 8
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 8
NutmegCT Variable compression? Other Cars 22
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
R TR2/3/3A Good Compression Triumph 1
3798j Fastronix Battery Compression Ends Restoration & Tools 4
F TR2/3/3A Compression Test Triumph 13
K TR2/3/3A Compression testing again... Triumph 4
HighAltitudeTR3 TR2/3/3A Compression Question Triumph 10
warwick-steve High compression head identification Austin Healey 16
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
Jim_Gruber Bugsy IV and Engine Compression :[ Spridgets 11
Martinld123 Compression check 1956 BN2 Austin Healey 7
2 TR2/3/3A compression numbers Triumph 1
P TR6 Latest compression test Triumph 11
MY66AH Compression woes Spridgets 11
S Unexpected Compression Readings Austin Healey 14
Gliderman8 TR6 Compression help in one cylinder Triumph 7
tinman58 TR2/3/3A Surprise on compression. Triumph 9
K TR2/3/3A Cylinder Head and Compression Ratio Triumph 0
T TR6 TR6 compression test Triumph 12
B TR6 Fuel tank to line compression fitting Triumph 1
tinman58 TR5/TR250 Compression # Triumph 9
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
M Compression test results Austin Healey 11
R TR2/3/3A Steering, stator tube compression sleeve? Triumph 4
Kleykamp TR2/3/3A compression numbers & smoking engine Triumph 20
S Bugeye 948cc Compression Spridgets 7
L 1275 Compression, Camshaft, et al Spridgets 16
me61ic Compression results - Worth Rebuiding? Austin Healey 13
Tinkerman TR2/3/3A 60 TR3A Compression test Triumph 15
D Austin Healey 100-6 Compression Austin Healey 1
P TR6 1971 TR6 compression Triumph 2
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
T Milling a head on a Stock 1275 for compression? Spridgets 13
RichBall For us 1500 guys, high compression head up on Ebay Spridgets 10
M TR4/4A TR4 Optimal Compression - 91 Octane Pump Gas Triumph 13
pkmh Compression Test Results for BJ8 Austin Healey 14
TulsaFred 1275 compression ratios and horsepower Spridgets 29
R TR4/4A TR4a engine compression Triumph 6
R Spitfire Lbs of compression Spec for 1979 Spitfire. Triumph 3
BN6_2197 Question on Engine Compression Austin Healey 9
M Compression test Triumph 25
RobT TR5/TR250 TR 250 Compression Ratio - is 10.4:1 too much? Triumph 9
PATR8 Wedge Compression rates for a TR8 Triumph 2
Morris Compression ratio Spridgets 12
