TR2/3/3A 1960 TR3A engine compression question.
Tinkerman
I just ran an engine compression check on my non starting post 60,000 engine and got the following numbers:
piston 1 through piston 3: 85
piston 4 75
So we have 85,85,85 and 75, which I feel, is too low. What should the numbers be for a stock TR3A?
This could be the root cause of my starting problem. If that is the case what do I do about it? How can low compression be fixed?
Your thoughts and comments, as always, greatly appreciated.
Cheers, Dick
TR3driver
Great Pumpkin - R.I.P
Normally, compression readings are only useful in a relative sense.
But those are low enough to probably indicate some sort of systemic problem. I would double-check the valve timing, valve lash, and whether the gauge is accurate.
If that is all OK, start looking for where the air is escaping from the cylinders. You can try the old trick of squirting a small amount of oil into each cylinder just before checking it's compression again. If the reading goes up dramatically, you've probably got bad rings. A small bump says that's probably not the issue (which more or less leaves valves unless you've got something really weird like 4 broken pistons).
But a better test IMO is to pressurize each cylinder and listen for the hiss of escaping air. With the compression gauge I have, it's a fairly simple matter to unscrew the hose from the gauge, and connect an airline fitting with the help of a few adapters. There's a Schrader valve in the tip of the hose (where it screws into the plug hole) that has to be removed.
Of course, by now, it's fairly certain the engine will have to come apart; and the problem(s) will likely be obvious once you can inspect the valve seats, piston rings, etc. But it's good to know what you're looking for, just in case.
The good news is that you can do that with the engine still in the car, without pulling the front bumper, apron, radiator, etc.
Geo Hahn
No disagreement with anything Randall said - but I would think that an engine with 85/85/85/75 dry compression would start and run if there was nothing else amiss. Might even run rather well.
...my non starting post 60,000 engine...
I do not recall what symptoms you have but it might be worthwhile to determine if anything else is wrong before you start tearing it down.
CJD
Since the engine sat so long, I would bet those readings are from gummed up rings. You could try freeing them before breaking into the engine by adding solvent in the plug holes every several hours and turning over the engine...repeating for a few days. May not work, but it's worth a try before having to break down the "new" engine.
I've run into that many times with motor bikes and old tractor engines. The interesting thing is if you could get it to start, the rings usually free themselves pretty quickly.
sp53
Try a different gauge and check the valve lash. I think it should pop even at 85psi. If you take #1 plug out, put your thumb over the plug hole and crank the engine until it puffs your thumb off-- then lift the dist cap off --where is the rotor pointing? Plus those little screws in the cap do not index exactly.
Got_All_4
You should do 3 compression strokes. Your first compression stroke should jump up rather quickly then 2 more with lesser increases. I'd do what John suggested. Squirt some penetrating fluid or Marvel Mystery Oil in the sparkplug holes and let that sit over night then crank the engine. may take a couple of times to get them loose but best if you can get it to start and run for a while.
Geo Hahn
Stating the obvious just in case -- you do need to have the throttle wide open when doing a compression test. Not opening it will yield low numbers as the cylinder will not suck in enough air to give proper compression.
T TR2/3/3A 1960 TR3A engine compartment color Triumph 8
G 1960 TR3A for sale $9,999 or best offer! Triumph Classifieds 3
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
Tinkerman TR2/3/3A Hood stick assembly 1960 tr3a Triumph 7
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
Tinkerman TR2/3/3A 1960 tr3a sheet metal fitment Triumph 6
Tinkerman TR2/3/3A 1960 TR3A carpet installation Triumph 5
Tinkerman TR2/3/3A 1960 TR3A Tonneau Capping Installation Triumph 1
Tinkerman TR2/3/3A 1960 TR3A Tonneau Trim Mill board Triumph 10
M_Pied_Lourd TR2/3/3A 1960 Triumph TR3A Trunk Seal Orientation Triumph 6
Tinkerman TR2/3/3A Prepping the grill for installation for my 1960 TR3A Triumph 1
Tinkerman TR2/3/3A Sealing fender to body 1960 TR3A Triumph 15
Tinkerman TR2/3/3A Windscreen mounting tips 1960 TR3A Triumph 2
Tinkerman TR2/3/3A 1960 TR3A Bottom Rubber Seal on the Windscreen Triumph 3
Tinkerman TR2/3/3A Tunnel installation question 1960 TR3A Triumph 11
Tinkerman TR2/3/3A Another Freeby from the past. For a 1960 TR3A Gas Tank Triumph 4
Tinkerman TR2/3/3A 1960 TR3A Holes in the tranny tunnel Triumph 11
Tinkerman TR2/3/3A Carpet underlayment, TR3A 1960 Triumph 10
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
D TR2/3/3A 1960 TR3a front suspension Triumph 2
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
D TR2/3/3A fitting windshield/frame to 1960 Tr3a & Brooklands screen removal Triumph 2
Tinkerman TR2/3/3A TR3A 1960 Gas on three out of four plugs ? Triumph 6
Tinkerman TR2/3/3A 1960 TR3A post 60,000 series seat pan covering Triumph 3
Tinkerman TR2/3/3A 1960 TR3A seat tack strips Triumph 1
Got_All_4 TR2/3/3A Finish on a 1960 TR3A Fluid reservoir? Triumph 6
60TR3A TR2/3/3A 1960 TR3A Small Mouth [Huh?] on eBay Triumph 63
M_Pied_Lourd TR2/3/3A 1960 TR3A Mystery G Triumph 24
Tinkerman TR2/3/3A 1960 TR3A Instrument Cluster Ground Post Screw Triumph 9
M_Pied_Lourd TR2/3/3A Restoration of TS 69891LO 1960 TR3A Triumph 36
T TR2/3/3A 1960 TR3A oil leak issue [imagine that!] Triumph 5
PAUL161 TR2/3/3A Colonal Tom Parkers 1960 TR3a For Sale! Triumph 3
T TR2/3/3A 1960 TR3A now with rack and pinion Triumph 22
Tinkerman TR2/3/3A Bulkhead Sealer Plate TR3A 1960 Triumph 3
D TR2/3/3A 1960 TR3A Paint Question Triumph 24
gubba TR4/4A 1960 TR3A with tr4 motor and tranny? Triumph 22
D TR2/3/3A 1960 TR3A Flasher Triumph 7
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Pool Dad 1960 TR3 engine serial number Triumph 14
F My 1960 BT7 History Search Austin Healey 1
poolboy General TR LeMans 1960 Triumph 8
jlaird 1960 AH Sprite Spridgets 96
O For Sale New Member from NJ 1960 TR3 Triumph Classifieds 1
C 1960 BT7 Thoughts Austin Healey 14
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
