Jim_Gruber
Guys here's the tale of the Compression Gauge.
Oil Pressure popped up to 60 psi after I primed the pump.
The Compression readings
#1 90 psi
#2 70 psi
#3 45 psi
#4 90 psi
So when I first started cranking this engine by hand there was a spot where the engine stopped and I could not turn over. I added a Tbs of oil to each spark plug hole and let it sit for two days. I then came back and alternated rotating directions never forcing anything. All of a sudden I could feel things giving way, backed up he other direction and things began to rotate freely through 360 degrees by hand turning the generator nut.
Supposedly this was a rebuilt engine. It could be as number plate is missing. Where do I go from here. Unknown how long this engine has been sitting. It could be years and years. Do I attempt to start it and see if a stuck ring gets unstuck. Pull the head and check valve gasket. Retorque things. This will not be the permanent engine. I've got a 1275 and a 5 speed that will be going into this BE but the 1275 needs a valve job/replacement head milled and valves seats checked.
Plan is to make this a rolling restoration while the other engine is being worked on. I'm also trying to get this car running for Dayton British Car Days on August 6. Thoughts gentleman?
#1 90 psi
#2 70 psi
#3 45 psi
#4 90 psi
