rnpennington
I felt the car wasn’t running right so I skipped an Autocross today to check on it.
First thing I did was a compression test. Results were cylinders 1 – 4: 90, 150, 170, 0.
Added oil to cylinder 1 and 4 results 120, 0.
Could it be just valves or am I realistically looking at an engine rebuild? If valves, should I just have a machine shop do it?
I have done an engine before (VW) many years ago, but want to make sure all is correct the first time.
If I go the engine route, what do you guys think would be a reasonable time/budget. I saw Rimmer has an entire engine rebuild kit for about a grand.
If I do have to rebuild and pull the engine, should I consider replacing the transmission as well?
