TR6 TR6 fuel line / mechanical fuel pump compression?
tdskip
Hi guys - dealing with the not uncommon issue of my new fuel pump having threads that are too deep for the compression fitting to work. Yes, it is leaking as a result.
Is the fix for this to buy a second one of these and slip it on the fuel line so it will tighten up before the compression fitting before the threads bottom out?
RomanH
I have tried that. It didn't work for me. The solution is to get the proper compression fitting. The problem with that is that it seems no one has them. Earlier this year while helping to get a car running we got so disgusted by not being able to stop the fuel leak that we converted from the steel hard line after the fuel pump to a rubber fuel line. We took off the fuel pump and got a brass barb fitting and taped the fuel pump body to accept the fitting. The owner has been able to drive the car with no leaks ever since.
If you do find the proper size fitting, post it so that I could also get some!
DNK
Tom- we just had that discussion here a couple of weeks ago.
Somebody sells the fix online.
Someone will pop up with the answer
T
tdskip
I went to a specialty store and they had a larger (longer and fatter but still correct diameter)compression fitting that appears to have done the job. Roman, is there a hot rod shop or industrial hose company nearby?
71tr TR6 fuel line TR6 Triumph 2
71tr TR6 fuel line TR6 Triumph 6
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
F TR6 TR6 Fuel Pump Priming Triumph 11
sundown TR6 1973 TR6 fuel pump Triumph 4
B TR6 TR6 Fuel Filter keeps clogging Triumph 9
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
D TR6 1976 TR6 Fuel Lines Triumph 7
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
G TR6 TR6 fuel tank fitting size. Triumph 14
Gliderman8 TR6 Troubleshoot a TR6 Fuel gauge problem Triumph 36
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
M TR6 TR6 Fuel Delivery Issue Triumph 18
I TR6 TR6 fuel pipe nut source? Triumph 5
I TR6 TR6 fuel pump - how do I replace these? Triumph 18
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
T TR6 tr6 fuel sending unit Triumph 5
G TR6 TR6 Fuel Injection ? Triumph 8
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
BobbyD TR6 TR6 Fuel Pump Triumph 1
Brosky TR6 Fuel Pump Kit for TR6 Triumph 3
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
DNK TR6 TR6 fuel lines. Triumph 20
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
B TR6 71 TR6 Fuel Tank firewall? Triumph 6
J TR6 Just another whining TR6 fuel pump again? Triumph 19
SCguy TR6 How can you tell if your TR6 fuel pump is working? Triumph 4
I TR6 TR6 Fuel gauge help Triumph 7
E TR6 TR6 Fuel / Mixture ? Triumph 4
V TR6 Oil and Fuel for TR6 Triumph 6
I TR6 Fuel injection for TR6 Triumph 4
G TR6 Free OE TR6 Fuel Pump.....................8 bucks. Triumph 2
V TR6 TR6 Fuel pump spares Triumph 8
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
G TR6 Fuel sender resistance for TR6 Triumph 1
I TR6 fuel lines for 69 TR6 Triumph 3
Tullamore TR6 TR6 Fuel Leak Triumph 4
Morris TR6 TR6 Fuel Injection Triumph 21
padjo TR6 TR6 Fuel Pump Triumph 1
M TR6 TR6 FUEL TANK VENT PIPE Triumph 3
BierRunner TR6 TR6 Gas Pedal Triumph 2
nichola TR6 Another TR6 back on the road Triumph 1
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
E TR6 74 TR6 - “ A Post Seal” Triumph 0
J Wanted TR6 seat vinyl Triumph Classifieds 1
