TR2/3/3A Clutch Throw out bearing to Carrier installation "tool"?
karls59tr
Bronze
Can't remember what forum where I saw this tool on. Basically it's a large washer with a nut and bolt that you tighten and it applies even pressure to push the bearing on to the carrier. Anyone know who sells this tool?
Darrell_Walker
The Roaster Factory, at least they used to. I'm not finding it right now in any of their online catalogs.
Darrell_Walker
TRF's claim was that the tool rotates the bearing as it presses it on, and that is a better way to install the bearing. A vise or press won't do that. Now that may have just been hype.
Healey_Z
I put the carrier in the freezer for an hour, the TOB on top of a light bulb for less than that, and with minimal force of a vice went right on.
K
karls59tr
Bronze
I'm going to try your method. I guess the danger of using a vice without the freezing and cooling method is that the pressure from the vice could damage the bearing race.
CJD
The races will take a lot of pressure...just don't be tempted to use a hammer on the bearing itself. That is what will brinnel the races.
Healey_Z
I have a really nice vice (found on Craigslist for $50, ended up being a $700 machinist vice that was from an air force base) with big and soft jaws. Depending on your vice, I would also use caution or use two 2x4's on each side to help assure even pressure across the bearing. Mine literally went on with one crank of the arm of the vice.
TR3driver
Great Pumpkin - R.I.P
I think the whole thing with the bolt & washers came about back when they were having unexplained early failures of the throwout bearing. I believe it was later decided that the real problem was the bearings and/or sleeves not being made properly; but it doesn't hurt to take extra care with them.
71tr clutch - hydraulic throw out bearing Triumph 13
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
Pythias Clutch Throw? Datsun 5 speed. Spridgets 9
johnrip Wedge TR7 Clutch Throw out noise? Triumph 1
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Clutch Master Cylinders? Triumph 1
R TR2/3/3A Clutch Engagement Triumph 31
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
T TR2/3/3A TR3A clutch problem Triumph 15
S MGB 1978, replacing the clutch. MG 3
S MGB clutch replacement MG 7
D BJ7 Clutch Austin Healey 6
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
