choke connection 67B
19_again
I can't seem to understand this system. How am I supposed to pull the choke lever up from below the lever? I know to bring the cable up through the abutment, and then lock it through the ferrule above. But if it's locked in place how can pulling on it move it, much less raise it?
There is a little play at the dash, perhaps a quarter inch. I'd love to see a picture of a working unit.
There is also a new development of a sticking throttle, I've traced it to the new throttle cable sort of binding in the sheathing, I'll be driving along and it will stick unless I hit the gas pedal very sharply. It's almost as if there should be a return spring on the pedal assembly,but it's not there.
Mike
David_DuBois
Mike - The trick is that the inner and outer sheath move in relation to one another. If one of them is fixed solidly, and you pull on the choke knob, the other will move. This seems counter intuitive, but it works and works well. there was just a discussion about this on (dare I say it) The MG Experience, MGB Forum.
Cheers,
19_again
19_again
Thanks Dave,
I guess I'll need to really tighten up the connection at the dash, as it is a tiny bit sloppy. I'll heed the advice to disconnect the battery.The real pita is that we had it set up correctly a week ago before we had to pull the unit again to correctly install the throw out bearing fork. I have never understood it, but I'm smart enough to know that I'm not smart enough to understand everything. As long it works, that is fine. But with the current hookup, I'm not getting any movement on the cable at all, nada. Bupkus. Hopefully with a tighter connection of the knob it will improve. That makes about as much sense as pulling up from below. The explanation over at the experience was very good indeed.
Mike
Platinum
Yup. The outer sheath is doin' the "work" in this case. Kinda: "Push-me-pull-you".
The "slop" can be taken up at the inner cable attachment point on the air cleaner bracket. Tightening the bezel behind the dash can be a challenge, DO heed the "disconnect battery before attempting any repairs" advice. Smoke escapes rapidly when you're upside-down under there. A "crow's foot" can make that job easier. Can't recall the size of the nut (they vary with cable mfgr anyway) but it's near-impossible with a regular line wrench.
Sorry I couldn't get a photo to ya, Mike. We were sittin' on a restaurant patio havin' an outdoor lunch with friends. I was pleased to take your call, just not in any condition/position to render aid. 200 miles south, island visit.
And don't hesitate to call <span style="font-style: italic">any</span> time. That was an impromptu trip, a welcome retreat. Had we been at th' hovel it would have been different. Profuse apologies!
19_again
19_again
Doc, not to worry. Nothing to apologize for at your end. Sorry to bother you on a Saturday, I know the office hours. :wink: Turns out no matter how many times I ask that choke question I get the same answer, "It's supposed to work that way" Definition of insanity is to repeat the same thing over and over and expect different results. Still you gotta wonder why they decided that three left turns was better than one right.
Mike
bcliff
As far as the sticking throttle goes, there should not be a return spring on the pedal. The return springs are on the engine side of the carb unit. There should be three springs total as far as I know. If the cable itself is what is sticking no amount of springs will keep it from getting stuck. I would imagine the issue is a frayed cable as they are wound and rather stiff, which can lead to fraying. I've found the G string from a bass guitar is an acceptable roadside replacement for a bad cable, though I wouldn't use it any longer than it took to get the car home as I can't speak for the reliability in the long run. Always handy to keep random junk in your toolbox, has kept me from expensive towings a few times.
(Kensai not realizing he was signed in as Bcliff...)
Platinum
:lol:
Personality conflicts?!? :jester:
Bicycle brake cable, Teflon lined type, inna glovebox.
Kensai
DrEntropy said:
:lol:
Thankfully no...
Bcliff is my father. I was posting from a laptop he is normally logged in on while I was away from my regular computer and did not consider that I was logged in as someone other than myself.
I suppose bicycle cable would work but it just wouldn't have the sweet ratcheting feel/sound that you get from a wound guitar string...
19_again
19_again
Turned out to be the new throttle cable just needed a little white grease, problem solved. Now I just need to re-install the gear shift lever, I installed it backwards and it was hitting the chrome trim ring when trying to go into third. You'd think if you could only install something one of two ways, that you'd have a fifty-fifty chance of getting it right. Not me! So far on this tranny replacement I've installed both the throw out bearing and the gearshift lever bassackwards, fortunately the lever is a tad easier to fix.
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
af3683 Choke Cable Connection to Rod Assembly Fork Triumph 7
drooartz Choke cable connection? Spridgets 8
Nelson Choke cable connection? Spridgets 5
U Electronic Connection to Choke? Triumph 1
Todd78d Bugeye choke linkage Spridgets 5
Todd78d Choke Linkage Photo Austin Healey 0
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
D BT7 Choke Assembly Austin Healey 18
P MGB Zenith water choke gasket needed MG 4
D Choke Cable Length Austin Healey 0
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
L MGB 1977 MGB will only run on full choke MG 53
SherpaPilot TR6 Choke Assembly Triumph 0
M Choke Linkage Austin Healey 3
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
TomMull TR2/3/3A Which choke cable Triumph 12
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K TR2/3/3A Couple of choke questions Triumph 1
K Choke cable replacement Austin Healey 1
D AH 300O MK1 Choke Knob Position Austin Healey 5
R Jensen-Healey Choke? Other British Cars 1
F TR2/3/3A Choke Cable Problem Triumph 29
F Choke sticking Austin Healey 22
N Enrichener [choke] wire Austin Healey 1
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
F TR2/3/3A Choke Triumph 1
edkap2002 TR6 72 tr6 choke cable Triumph 4
Patrick67BJ8 BJ8 Choke Cables Austin Healey 5
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR2/3/3A choke operation from the factory !!!! Triumph 29
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
sparkydave Zenith auto choke coming loose Spridgets 3
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
TomMull TR2/3/3A Choke on new to me TR3 Triumph 16
L Choke Mechanism 100/6 Austin Healey 26
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
1 TR6 Tr6 needs choke to run good Triumph 11
