Check out this Porsche
Bret
I’d like to see how she handles on a road course. The apex entry/exit strategy alone would be a laugh.
Guess you’d never have to worry about getting stuck in the gravel or loose sod.
lawguy
Hey, don't laugh. This is probably the only Porsche that can cover an entire road course at top speed, never touching the brakes.
Mickey Richaud
So THAT'S where the Cayenne came from!
Eric
Now if I buy that and park it next to my Ferguson (Standard Vanguard engine - same as a TR3/4), I'd have a Triumph roadster and a Porsche roadster! Imagine the Road & Track comparison test!
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
AngliaGT In Check,VA Today Spotted 2
Rob Glasgow Check Strap Assembly Austin Healey 5
F TR2/3/3A Check strap alignment Triumph 11
T General Tech Once again, check the easy stuff Triumph 2
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
S Price check on TR3A valve cover Triumph Classifieds 0
Twit TR4/4A early tr4 check straps Triumph 4
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Lukens For Sale Check out this tr3 project for sale... A real treasure trove Triumph Classifieds 0
V TR2/3/3A Vertical link check Triumph 2
R TR4/4A Door check straps Triumph 7
68_sprite Check the August Oprah Magazine Austin Healey 5
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
S Door Check Strap Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
C Rough Idle - What to check? Austin Healey 12
KVH TR4/4A Door Check Straps Triumph 11
S Overdrive Wiring Check Austin Healey 12
Michael Oritt Door check installation Austin Healey 7
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
warwick-steve Brake drum check and lubrication Austin Healey 9
Rut Sanity check! Spridgets 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
Mickey Richaud General Tech Always Check the Fundamentals MG 10
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
D TR2/3/3A Door check bracket? Triumph 7
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
Martinld123 Compression check 1956 BN2 Austin Healey 7
M BN1 door check replacement Austin Healey 9
R Last minute check before engine install Austin Healey 26
Boink Check out some Sprite shots at the Portland ABFM... Spridgets 1
Rut TR4/4A Get out your check books! Triumph 10
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
S How to check Dwell on a MK I 3000? Austin Healey 27
K TR2/3/3A Re: TR3 Bump stops and check straps. Triumph 18
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
jlaird Check Spam folder Spridgets 3
I TR6 Got in a wreck - need some help on who to take it to and what to check Triumph 48
HealeyDave Door Check Friction Adjustment Austin Healey 12
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
sundown TR6 1973 TR6 door check straps Triumph 3
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
drooartz General Tech Check those brake hoses! MG 11
sundown TR6 Door check strap Triumph 3
