I am still working on checking how all the pieces are fitting together. Doors seem to be fitting well even with the skin set on the frame . I just received a set of NOS check straps and are nice parts. Now I have discovered that the check strap when mounted in the door frame do not line up with the bracket in the A post. The check strap bracket relation to the hinge mounting cage nuts on the A post has not changed. I have no way of knowing if these doors are original to my car so that might be the problem. I tried to bend the check strap slightly and the A post bracket and got it so I could put a bolt in the bracket and it stops it from opening too far but I can not close the door with out the check strap binding up. The mis alignment looks to be 3/16"(same on both doors). I have studied it and looks to me the best solution is to move the holes in the door frame so that everything lines up correctly. Any thoughts are welcome. Frank
