Check out these carburettors!
jsneddon
[ QUOTE ]
Whats micro-polishing?
[/ QUOTE ]
He won't say - I think he was on the board here for a while (Jeff Palya of Paltech)...
from his site:
"The Micro-polishing process entails a trade secret mechanical motion using custom made equipment & custom formulated media that are not available on the market. There are no chemicals used in the process."
Some sort of media and a tumbler/vibrator thingy I think.
You can get pretty similar results with white rouge and a buffing wheel and a dremel with a buffing nub for all the nooks and crannies.
That being said they all are going to turn flat again if you don't really keep up on them. Some people have suggested clear coat which may be fine for the externals but your throats and all the internal bits are going to still get gunky.
To each his own I guess. /ubbthreads/images/graemlins/grin.gif
Brosky
I'm just guessing, but in my business as a sales rep, I've seen similar results when plastic media is used in place of traditional abrasive tumbling media. And where do they get the plastic media, you might ask? What do think happens to all of the holes that are made in plastic buttons?
Dunkin Donuts made a fortune selling donut holes and years ago a button manufacturer found a a use for his scrap products.
This process is very compatible in the medical device industry as no toxic chemicals are used to polish the metals that may enter the body in a surgical device. Done correctly, it will pull even baked on powder coat right off of stainless steel parts and leave the metal looking beautiful, without scratching or etch marks.
71tr
Jeff Palya does great work. He did my SU's and they are concourse quality. I tried white rouge and even light media blasting before turning to Jeff and couldn't come close to his results. Very pleased with his work as you can see plus he rebuilt the carbs while he was at it.
jsneddon
That's pretty cool Brosky... always someone out there figuring how to make a buck before I do... /ubbthreads/images/graemlins/smile.gif
Now Banjo will have to fire up his home-made "Tumblematic 2000" clothes dryer full of button holes, drive away all the neighborhood dogs with the racket, and let us know how it works /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/smile.gif
vettedog72
I understand the tumbling action all ways takes the edge off of the objects being tumbled. If that is true, I don't see how a tumbler would be good for carb parts.
bobh
Plastic media is available is a variety of sizes, shapes and hardness. Button holes is an old term that was probably based on some of the earlier media. Each type has a recommended use. Although I've never seen this, some media manufacturers claim that you can strip paint one layer at a time with the correct media, equipment and operator. Plastic is much easier on the base material. Ground walnut shells are used in some blasting. Another type of blasting that is becoming more common is soda blasting. I believe it uses baking soda. This one is supposed to be environmentally safe.
Tumbling media is also customizable. Artifical stones made from ceramics are common is a machine shop where tumbling is used to de-burr parts. Ammunition reloaders use softer media to polish their casings before reloading. The key is to match the media to the material. Media that is softer than the material will not abrade the base material. Blasting, even with a soft media, can generate enough heat to warp the material.
tomshobby
trfourtune
i wonder if micropolishing is actually ultrasonic cleaning, which could be considered "micro-polishing" this is the REAL thing to do with those grungy carbs.
rob
bobh
Tom,
It would be interesting to see how a small carb part would look after going through the tumbler. The walnut shells should do a pretty good job of cleaning and polishing. Would your tumbler hold a Hotwheels car? They are diecast. If it wouldn't mess up your media it would be interesting to see the finish on a small diecast car after tumbling.
Brosky
Bob is absolutely correct in his earlier post regarding the various types of media now available. I just made fun of the button hole, "one man's waste is another mans treasure" scenario, but that again could have been said for walnut shells.
Who's the luckyguy that gets to eat all of the walnuts?
One of my principals uses over 30 different types of media to "break the edges" or de-burr, for lack of a better descriptive, many of the parts that are stamped from the progressive dies that we build. These have extremely tight tolerances on the surface finish and edge condition, so it really can be a science in itself.
I think that the carbs have a very agressive cleaning process and then the trick is in the polishing and possibly acid bath after the initial clean cycle.
I just sent my wiper motor here to be polished before having my engine compartment repainted. I'll post pics after I get it back. https://www.tr6car11.bravehost.com/service.html
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
AngliaGT In Check,VA Today Spotted 2
Rob Glasgow Check Strap Assembly Austin Healey 5
F TR2/3/3A Check strap alignment Triumph 11
T General Tech Once again, check the easy stuff Triumph 2
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
S Price check on TR3A valve cover Triumph Classifieds 0
Twit TR4/4A early tr4 check straps Triumph 4
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Lukens For Sale Check out this tr3 project for sale... A real treasure trove Triumph Classifieds 0
V TR2/3/3A Vertical link check Triumph 2
R TR4/4A Door check straps Triumph 7
68_sprite Check the August Oprah Magazine Austin Healey 5
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
S Door Check Strap Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
C Rough Idle - What to check? Austin Healey 12
KVH TR4/4A Door Check Straps Triumph 11
S Overdrive Wiring Check Austin Healey 12
Michael Oritt Door check installation Austin Healey 7
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
warwick-steve Brake drum check and lubrication Austin Healey 9
Rut Sanity check! Spridgets 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
Mickey Richaud General Tech Always Check the Fundamentals MG 10
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
D TR2/3/3A Door check bracket? Triumph 7
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
Martinld123 Compression check 1956 BN2 Austin Healey 7
M BN1 door check replacement Austin Healey 9
R Last minute check before engine install Austin Healey 26
Boink Check out some Sprite shots at the Portland ABFM... Spridgets 1
Rut TR4/4A Get out your check books! Triumph 10
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
S How to check Dwell on a MK I 3000? Austin Healey 27
K TR2/3/3A Re: TR3 Bump stops and check straps. Triumph 18
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
jlaird Check Spam folder Spridgets 3
I TR6 Got in a wreck - need some help on who to take it to and what to check Triumph 48
HealeyDave Door Check Friction Adjustment Austin Healey 12
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
sundown TR6 1973 TR6 door check straps Triumph 3
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
drooartz General Tech Check those brake hoses! MG 11
sundown TR6 Door check strap Triumph 3
