Carburetor removal
AUSMHLY
Got my 64 BJ8 back from the body shop. I was told that because it was bead blasted, that I should remove the carburetors and make sure no dust got in there. If any did, that running the car will not be good. So a friend, who knows engines offered to come over and remove it and take a look around.
Prior to having the car bead blasted, I did remove the air cleaners and put duct tape over the openings. One can never be to sure where that dust gets into. It got into my fuel gauge, which I had to send out and repair. So, I don't want to take any chances.
Anything I should know or should tell him about this project.
What oil should I use in the carburetors? Moss lists Dashpot Oil. Anything I can use/get locally?
Any other fluids or anything else I'll need when putting them back on the car?
Any other areas I should be concerned about?
thank you, Roger
20 weight works just fine.
----Plain ole transmission fluid.---Keoke
[ QUOTE ]
[/ QUOTE ]
------ /ubbthreads/images/graemlins/savewave.gif
------ Yep Roger, a small powerful telescopic magnet and a bushel full of PATIENCE.---Keoke- /ubbthreads/images/graemlins/grin.gif
Got the PATIENCE thing down. Had a good teacher. Finally after 19 months, I got my car back from the body shop. Thank you very much.
Now I must remember to get some sleep. I'm putting the car back together. Working on it every night after work and full weekends. I'm just so happy to have it back. And grateful to have all the help and support of everyone here.
Cheers, Roger
Ro;ger, there are some ratchet type stubby wrenches that will make the removal of the four nuts of the air cleaners easier. Also you may want to stuff a rag into the opening of the frame below the front carb. I've found many parts in there form the PO when I dropped a nut and washer in there.
Right on TH. Thanks for those tips. I too have found many washers, nuts, lock nuts, bolts, screws all over the place when I got the car back from the body shop. Yet to find any loose change. Cheers, roger
C Carburetor Removal on a BT7 Austin Healey 7
pkmh HD8 SU Carburetor removal Austin Healey 48
F Holley Carburetor on Sprite? Spridgets 6
G TR2/3/3A SU carburetor running rich Triumph 9
J Carburetor Banjo Seals Austin Healey 11
zoohow TR6 Carburetor Conversion kit Triumph 2
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
P Zenith Carburetor Triumph 2
K Carburetor options for a 66 Austin 1100 ? British Motor Corp 3
KVH General Tech HS6 Carburetor Bushings Triumph 10
A Spitfire Weber Carburetor Triumph 0
B gas leak underneath the carburetor Restoration & Tools 2
A TR6 Carburetor help Triumph 5
G TR6 Hacked carburetor? Triumph 6
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
AUSMHLY SU Carburetor Synchronizing Kit on eBay Austin Healey 16
C TR6 Carburetor Throttle Linkage Triumph 10
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
FlyingCat Spitfire No Gas to Carburetor Triumph 18
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
F TR6 Carburetor issues at low rpms webers Triumph 23
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
D TR2/3/3A '59 TR3A SU carburetor Triumph 4
AUSMHLY Front carburetor Austin Healey 11
B BJ7 Carburettor / Carburetor spacers Austin Healey 2
G Gasket sequence manifold to carburetor Austin Healey 4
ckeithjordan TR2/3/3A Carburetor Rebuild Triumph 26
F General MG Help needed with su dual carburetor identification MG 4
KVH TR4/4A Carburetor float bowls Triumph 8
M BN1 carburetor fuel line Austin Healey 9
fpstude TR2/3/3A TR3 Carburetor Adjustment Triumph 6
D S.U. HD8 Carburetor Drawing Austin Healey 6
svtmikey GT6 C.D.S.E.V carburetor question Triumph 5
W Please help ID this unusual [& beautiful] carburetor adapter Other British Cars 4
Lutz Kramer Carburetor gaskets Austin Healey 8
B BT7 carburetor - choke - fuel questions Austin Healey 5
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Keith_M carburetor woes Spridgets 17
C HD6 Carburetor Spacer Blocks Austin Healey 4
C Carbon Deposits in Carburetor Austin Healey 3
T 1933 Standard Little Nine Carburetor Other British Cars 8
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
D Wedge TR7 Carburetor losing dashpot oil Triumph 8
bigbadbluetr6 TR6 TR-6 Carburetor rebuild kit Triumph 6
DornTRoriginal TR2/3/3A Carburetor Link Rod Ass'y Installation and Fuel Line Installation Triumph 1
