twas_brillig
I bought 4 speed bleeders from a local speed shop and installed them in our BE: they're Russell Part Number 639590; and 3/8 x 24 NF thread. They fit all four wheels.
Note that if you're bleeding an empty system, you may want someone to have a look at the clear plastic tubing you've got connected to the bleeders to see if there's any bubbles.
I pumped a fair bit of fluid through to get it all filled up etc. but the pedal was still soft, so enlisted my wife to pump and there was a small stream of bubbles in the right front wheel. Pedal is quite firm now, but might have to change a slave cylinder, so won't worry about final bleeding until then.
Doing the brake fluid change every couple of years will be a piece of cake with them now. For the other BE, I might find someone who makes stainless ones and order them.
Doug
Doug
