jjbunn
In the course of doing the brakes, I took off the brake pressure warning switch to check it out. Here are a couple of photos:
I've been trying to understand how this switch works, and if it's broken or not. It sure looks broken!
I can see that the brass end is supposed to move up into the switch if the pressure is unequal between the front/back circuits. But, inside the switch, I don't see how the contact between the incoming wires is supposed to be made when the plunger is fully in the switch.
Is my switch missing one or more parts? Has something broken off inside the switch body?
