TR2/3/3A brake pressure switch tr3
martx-5
I went to NAPA Online and came up with the following numbers...
BA 2010130 -- w/push on connectors
ECH SL144 -- w/screw type connectors
They even show the pictures, and they both look correct.
Banjo
COOL.
Now, if you went in and asked them for that application, they'd laugh at you.
hand them that part number and they don't blink.
hhhmmmmmmmm.
jsneddon
i took a look at their website and they sell what they claim is a carb gasket kit for a TR3 and they actually use the word "SU"... anyone actually buy one from them? it's 18 bucks but it doesn't say if it is for 1 carb or 2.
6 E-Type brake light pressure switch location Jaguar 5
B T-Series MGB Brake Pressure Switch MG 2
P Changing Brake Fluid & Brake Pressure Switch Austin Healey 17
S How to test a Brake Pressure Failure Switch Triumph 7
X T-Series Brake pressure failure switch MG 4
X T-Series Brake pressure failure switch MG 3
glemon Brake Pressure Switch Wiring Triumph 2
jjbunn T-Series Brake Pressure Warning Switch MG 10
angelfj1 TR5/TR250 TR-250 Brake Differential Pressure Valve/Switch Triumph 3
cutlass29 Spitfire spitfire mk3 '70 brake pressure switch pdwa Triumph 1
Woodie brake pressure failure switch Spridgets 15
ecurie_ecosse Brake pressure failure switch. Spridgets 8
T brake pressure switch assembly Spridgets 6
B TR2/3/3A Bubbling in brake reservoir. No pressure in lines Triumph 5
SherpaPilot TR6 Brake Pressure Problem Triumph 8
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
Gerry M TR6 Brake warning light & oil pressure light stay on Triumph 2
TomChar TR6 '74 brake failure / oil pressure / ARV wiring question Triumph 19
R Vanishing Brake Pressure Austin Healey 18
smaceng TR6 TR6 brake pressure balance valve Triumph 2
jhorton3 Brake Pressure Sensor Options Spridgets 3
S homemade brake pressure bleeders Triumph 9
hondo402000 TR6 71 TR6 Brake warning light and oil pressure light Triumph 6
JodyFKerr Spitfire Brake pressure sensor leaking ['78 Spitfire] Triumph 6
Johnny What does "excessive brake fluid pressure" mean? Austin Healey 21
Randy Harris Brake Lights Work Only With Heavy Pedal Pressure Austin Healey 12
weewillie brake pressure warning lamp Spridgets 12
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
