Not sure what the actual name is of the switch assembly mounted on the driver's right inner fender. You know, has the 5 brake lines running to it. Mine is brass but I think they made them in cast iron also.
Anyway, mine was leaking out the switch so I ordered a rebuild kit. When I took it apart I realized it had different seals than the kit. When looking it my 2 Spridget workshop manuals I can see that the kit it probably correct but it's my part that is different. Instead of using O-rings for seals, mine has actual cup seals like a master cylinder. The O-rings certainly don't fit.
My car is a 72 Midget & 69 Sprite combined so I'm not exactly sure which car it came off of. Has anyone seen one of these with cup seals? I suppose it's possible that this part may be from some other Brit car that was swapped some years back.
It's a stupid little part to be holding me up from getting out to enjoy the weather. I guess I could bypass the whole thing with some fittings.
Let me know if anyone knows anything about this part. Thanks.
Lee
Lee
