ADDCO 130 Front Sway Bar
Tim Tucker
Has anyone ever bought an ADDCO 130 sway bar? I just got mine from TRF and am very confused. I see no way this will fit. It is too narrow and not deep enough from bar to mounting holes. Any help or opinions are welcome. FWIW, The mounts and endlinks look workable. Thanks for all responses.
Tim
Picture of Bar I just received (33" from hole-hole; 5" deep):
Instruction sheet I just received says ADDCO130 on it and talks about installation on a TR250 and TR6???:
Here is what I found over the years on the web concerning an ADDCO bar and TR4s:
The ADDCO128 looks correct (at the least the instructions do):
ADDCO 128 Instruction Sheet
MANY THANKS!!
Tim
tinman58
I think you have the wrong one. I just went out and measured mine (addco) and it is 29" hole to hole and about 9" deep and it is bent almost 90 degrees. My instructions look like the 128 sheet you have. I hope that it helps.
TR3driver
Great Pumpkin - R.I.P
130 is the bar listed in the ADDCO catalog for the front of a TR4; but that sure doesn't look right to me. I would suggest calling the folks at ADDCO and asking. The bar they shipped me for the rear of my TR3A many years ago just did not fit as designed; and they fairly quickly sent me some different brackets (for free) that made it work. The bar also had to be tweaked a bit, which they told me how to do.
TR4nut
130 Sounds right for a TR4 kit, but that is not a TR4 bar - the TR4 bar arms are bent closer to 90 degrees and I think are a little deeper.
Also doesn't look like the right bar for a TR6, either, based on the kit Jegs shows:
Jegs Addco Bars
bobh ADDCO Sway Bars and 30 Year Old Bushings Triumph 2
J 145 - 130 - 155 - 160 warm compression test Triumph 10
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
G MGB '71 MGB Front End Rebuild MG 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
X Front End Alignment Austin Healey 14
FrogPond "57 100E Front Hubs on E494A Spindles ? Other British Cars 6
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
