100/6 Front Wheel Alignment
P
prutland
After pulling apart the front suspension on my 100/6 to replace bushes and the like, I have a conundrum in terms of the resulting wheel alignment.
Works completed were essentially to pull all the front suspension apart to replace the following:
  • lower fulcrum pins and rubber bushes
  • trunnion pins and rubber bushes
  • trunnion bearings
  • replace steering box oil seal and top felt bush
Apart from the front lever arm shock absorbers which remained in place, all the front suspension components were completely removed. All front suspension components were re-used after checking for wear except for those noted above as being replaced. Steering side rods and the cross-tube remained in place where practicable, and no adjustments were made to the cross tube length upon reassembly.
Upon reassembly it has become apparent that the front wheels have developed significant toe out (visible to the naked eye), and subsequently measured at about 1/2" (12-13mm) each side measured from front to rear of each wheel on the rim (using the "string line" method to verify). Notwithstanding that the suspension has been dismantled and reassembled, it is not obvious how such a change in the wheel alignment could have occurred. The cross tube was not touched and was reattached at 22.5" centre to centre (which seems to have been stated as a typical number on a previous post I have read).
I can adjust the cross tube to bring the wheels into alignment, but it would require shortening as it is at the limit of its adjustment inwards at the moment. However, I am concerned that something might be amiss as the result of the reassembly and therefore I am reluctant to start adjusting the cross tube length in case something has been reassembled incorrectly. Noting that everything seems to be in its correct place and reassembled in accordance with Section L of the Workshop Manual.
Any thoughts on the above would be much appreciated.
Paul,
The first bullet (lower fulcrum pins and rubber bushes): do you mean the lower A-arm / chassis bushings? Are the stepped washers seated correctly in the chassis mounts' holes?
Did you remove the steering arms? Swapping them side to side will mess up the toe.
Some new tie rod ends are longer, resulting in toe out.
Ditto on the steering arms if you have switched them by mistake .
Thanks all for your responses.
A couple of photos of the completed install are attached (apologies they seem to have uploaded in landscape mode!).
To answer the questions posed:
  • Upper trunnions are installed correctly as per the Workshop Manual (see extract + photos).
  • The lower fulcrum pins and bushes mentioned are those where the lower A-arms are mounted on the chassis. Stepped washers and pins are pulled up tightly and the former are correctly located in the mounting bracket "holes".
  • Steering arms attached to the steering box and idler respectively have not been swapped as I only removed the one on the steering box. The idler and its arm remained in place.
  • The cross tube and its associated tie rod ends was not removed. It was only disconnected at the steering box end. No adjustment to it length was made on reassembly.
As I mentioned originally, I suspect I can get the front wheels correctly aligned by shortening the cross tube, it is just odd that the suspension has gone back together with such a discrepancy in toe-in (out) compared with what existed prior to carrying out the work.
Is the car sitting on the ground? If so, how does the camber look? When tightening the lower A-arm's inboard fulcrum pins, the car needs to be on the ground. Otherwise the suspension/tires won't sit properly.
Two of the above posters have suggested what your problem may be. But you have not responded to their specific point. The steering arms are item #40 in the exploded diagram. They are handed. That is, there is a right side and a left side. If you installed them incorrectly then you will have the exact problem you are describing.
Thanks for comments on the steering arms. Yes both steering arms #40 were removed, I was confusing the steering arms with the steering levers. As far as i am aware they have been remounted on the same sides as original as they were separately bagged.
I agree they are handed, as currently installed the arms slope upwards from their attachment to the hubs which appears consistent with the workshop manual and other posts.
I have subsequently shortened the cross tube / rod ends by about 10mm and this has easily reversed the toe out so perhaps I will just accept that the new bushes etc. have altered the alignment sufficient to throw it completely out. I will take tha car out for a couple of short trips around the block and see if anything untoward arises.
The photo in post #5 shows that the steering arm is on the correct side.
It also shows that you don't have a 2" block of wood under the shock arm. I hope you did when you tightened the A-arm bushings. Doing so, sets the suspension a approximately normal ride height so the rubber bushings don't get over-stressed on bumps.
Hi John,
Yes I used the 2" spacer before tightening up the suspension bolts. Once the springs are back in you cannot recreate the 2" it seems.
The test drive appeared to go OK, so I will get a proper wheel alignment and see how it goes from there.
