TR6 Throttle/Carb issues 73 TR-6
R
ringo1
I see the problem, the cap was wired wrong. I Need to shift them all one spot. currently # 5 wire is in the #1 spot. One more quick question, what is the easiest way to hook up a bump starter?
TuffTR250
Sorry, I misstated the position of the rotar. The Haynes manual says it should be pointing to 7 oclock, the position of the lead in the cap that goes to plug #1. I have attached the section out of the Haynes manual on installation of the distributor. These steps should have it set correctly. Notice the comment in the manual saying that the #1 piston must be at TDC and on it's firing stroke with both valves closed. This is covered in section 60 on page 43 on bottom right and continues at the top left of page 46 of the Haynes manual.
R
ringo1
I still need help here!
-When cylinder #1 is at TDC the rotor is pointed to 1 o’clock-cylinder #6. So the distributer was installed 180 degrees out?
-I wired the cap so the 1 o’clock position goes to cylinder #1 and the others accordingly.
-Advanced Distributer recommended setting timing at 14-17 degrees BTDC at idle, I set my static timing at 14 degrees and used a test light to set distributer position with test light. Rotate Dist. Counter clockwise between to lobes- no light, then clockwise until light just goes on-contact with lobe.
-Here is where I’m confused, my timing light does not light timing marks if connected to #1. It does register the timing scale if I connect it to #6! The light was showing about 20 degrees maybe a little more BTDC. And 15hg vacuum.
-I rotated Dist. Counterclockwise to position (in photo) bringing me to 17-18 BTDC with 10hg and engine not running as well.
-I tried putting plugs at distributer in normal pattern and the car wouldn’t start.
This all doesn’t seem correct or make sense to me to me?
NutmegCT
If I recall, you removed your old distributor and put in a different one.
Are you sure you oriented the shaft correctly? I've seen distributors put in 180 degrees off.
Tom M.
R
ringo1
I had it rebuilt by Advanced Distributers and a shop installed it and the the new fast street cam.
I believe it is 180 degrees off and moved plug wires according, but in my limited knowledge things still don’t seem right.
I want this running correctly so I can I sell it.
Gliderman8
Notice the "off-set" slot in the drive for the oil pump..... you should check to make sure the distributor was installed correctly. When fitting the distributor the "off-set" should be closest to the engine when installing the distributor drive shaft. It is possible that the distributor was not installed correctly thereby causing all these problems.
Notice
R
ringo1
Was hoping to avoid removing distributer. Looks like no other choice but to go down the rabbit hole!
Thank you
Gliderman8
Thank you
That off-set is not readily noticeable but now that you know what you're looking for you should see it. Good luck.
Gliderman8
Yeah, it slightly off-set
R
ringo1
Distributer drive gear was 180 degrees out. And it’s a bitch to get out, until you find the magic tool (mini pry-bar).
Switched gear around, off set towards engine, line more like 2-8 rather than 1-7.
Checked my end float for drive gear. I had no gasket, but looks like I need a .0835” gasket. Where can I get gaskets for this or what type of material do I need to make a gasket?
Gliderman8
Gliderman8
You might also check Moss Motors to see if they have it.
Platinum
For future reference, the geared shaft with the offset has the center hole threaded 1/4"-20 thread. a long 1/4-20 bolt makes it EASY to pull it out and reposition.
R
ringo1
So simple, lol. One would think with it that easy the majority of us would know and the manuals would state that method.
Thank you
Madflyer
What distributor do you have?? here are pic of my 1973 TR6 and my 1972 GT6. They are vac retard that only work at idle or low RPM. yours appear to be low RPM vac advanced won't work
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
R TR2/3/3A Carb throttle return spring tension Triumph 2
davidb AH 3000 tri-carb throttle shafts Austin Healey 13
B SU Carb throttle bushings! Austin Healey 3
B SU throttle shafts and carb rebuild Austin Healey 1
W HIF44 carb... throttle cable connection Spridgets 9
TexasSprite Rebushing HS2 Carb throttle shafts Spridgets 7
F TR2/3/3A TR3 Carb Throttle shaft Triumph 10
S HS2 SU dual carb throttle/choke linkage Spridgets 10
MadRiver Carb Question -- Blipping the throttle Triumph 11
Lin Carb Linkage and Throttle Cable Austin Healey 3
Lin Carb throttle linkage Triumph 11
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
S Overdrive Throttle Switch Austin Healey 4
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 25
Walter74 Throttle Cable Conversion Austin Healey 6
J Throttle Controls Identification Austin Healey 4
B RHD BJ8 Throttle Control Rods Austin Healey 9
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
C Jammed Throttle Linkage Austin Healey 3
R TR2/3/3A Throttle rod spring location Triumph 3
T BT7 throttle relay levers short and long Austin Healey 2
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
D TR4/4A SU HS6 throttle spindle size Triumph 20
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
warwick-steve Throttle shaft bearing/bush on bulkhead Austin Healey 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
Lukens TR2/3/3A Installing a throttle. Triumph 2
K TR2/3/3A Kangarooing on light throttle Triumph 14
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
catfood Throttle return mechanism on the BN1 Austin Healey 4
RickPA Overdrive throttle switch caused meltdown Austin Healey 2
M Throttle pedal problem Austin Healey 8
bighealeysource Strange problem with throttle staying open Austin Healey 6
A Throttle Pedal Height Austin Healey 17
Bob_Spidell Throttle Bushes Austin Healey 6
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Rob Glasgow Overdrive Throttle Switch Austin Healey 9
Rut TR4/4A SU throttle linkage and brackets Triumph 5
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
Lukens TR2/3/3A Anyone ever see a push/pull throttle mounted on the dash? Triumph 4
