Notice the "off-set" slot in the drive for the oil pump..... you should check to make sure the distributor was installed correctly. When fitting the distributor the "off-set" should be closest to the engine when installing the distributor drive shaft. It is possible that the distributor was not installed correctly thereby causing all these problems.I had it rebuilt by Advanced Distributers and a shop installed it and the the new fast street cam.
I believe it is 180 degrees off and moved plug wires according, but in my limited knowledge things still don’t seem right.
I want this running correctly so I can I sell it.
That off-set is not readily noticeable but now that you know what you're looking for you should see it. Good luck.Was hoping to avoid removing distributer. Looks like no other choice but to go down the rabbit hole!
Thank you
