SU fuel pump servicing
SteveHall64Healey
Can anyone provide guidance on proactive service that should be undertaken on an SU fuel pump? I understand that there are contacts inside the electrical side that should be cleaned periodically. If that is correct, how is this done? Are there any other regular service tasks recommended?
thanks
steve
Healey Nut
Replace it with the electronic version of the pump and never worry about it again .
The points can be filed, just like ignition points (be sure to clean them well by drawing some paper through them afterwards). After filing, they'll need to be re-adjusted, which involves rotating the diaphragm (the procedure is explained in the shop manual). Inspect the diaphragm for tears or cracks and, since you'll need to separate the valve section to get to the diaphragm, check for any crud in the valves (they can be removed easily, but be sure to note their orientation; they're directional).
ps. The SS pumps aren't bulletproof, and may require readjustment as the diaphragm can stiffen over time.
Jack T
Some, at least the square bodied pumps, have a cylindrical mesh filter inside. When I opened my 60+ y-o pump that filter was caked with crud.
The 4-cyl pumps have one of those as well. I've wondered why they switched from the earlier style, which worked OK--at least as well as other SU pumps--to the square-body which, at least now, are ridiculously priced (some owners sub later, less expensive pumps).
Fuel pumps have bedeviled car owners forever. My dad's '55 T-Bird had a mechanical fuel pump which we could never get to be reliable (how simple can it be, it's driven by the cam???). It would intermittently stall the engine, and I could never figure out why (I finally guessed the inlet valve was sticking, but I'll never know for sure). I had a collection of 4 or 5 pumps, which looked good, but they all had problems. The car was 6V, and it was always a gamble to get it to start, after sitting for a few days, before the battery died. I even sprung for a 'Carter' brand which I figured, since it was a famous carburettor brand would be quality, but it was the same Chinese crap sold cheaper by other vendors. I sold the car to my BFF, and he finally bypassed it with an electrical pump. Modern pumps have issues too, and they're a real PITA because they're in the gas tank, which usually has to be pulled/dropped to replace the pump.
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
sundown TR6 Fuel pump Triumph 10
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
