TR4/4A Speedometer Cable Routing
mweg87
We just buttoned up the gearbox cover on our 1964 TR4. We have the speedometer cable exiting from the rear of the cover, through the floor with the handbrake boot. We are not sure where to go after this. Somehow we need to get into the engine bay, over to the driver's (left) side, and into the speedo. How is this routed? Are there special clips or holes in the frame or anything like that? Any help and/or pictures would be greatly appreciated!
TomMull
I think it would have to be OD as I don't see how you could get the cable through the hand brake boot on a non OD transmission. On my TR3, which I think is routed similarly to the TR4, the cable goes from the hand brake boot down under the main case of the transmission and then up in front of the left hand firewall and to inside through the same grommet as the non-OD used. It is not an elegant solution but seems to work. Of course since my OD is not original, it may be a poor example.
Tom
Geo Hahn
Original route for a cable coming from an OD box with an angle drive on a LHD car takes it forward along the gearbox, then crossing the engine bay along the front edge of the battery box (P-clip there I think) then on to the usual grommet on the LH firewall to the speedo.
TomMull
Thanks Geo, My set up certainly didn't look very tidy coming through the handbrake boot but apparently this was a common hack with OD conversion, rather than buying the 90 degree adapter.
Tom
TR3driver
Great Pumpkin - R.I.P
The angle drive wasn't introduced until later, at TR4A (where the handbrake boot was no longer in position to provide the passage). They are enough of a pain that IMO the early setup is actually better.
Keep in mind you don't want any sharp bends in the speedo cable. Minimum radius installed is 6", with no bends at all within 2" of connections.
M
mweg87
Update: On further inspection I found a couple of clips on the right side of the frame that obviously were for the cable. Then ran into engine bay near the starter, past the battery area, and into the cockpit. We don't have a battery box yet so I just zip tied it to the heater pipe on the rear of the engine for now. Thanks for the help!
B Speedometer Cable Routing Austin Healey 9
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
C routing of speedometer cable on BN6? Austin Healey 11
J TR2/3/3A Speedometer cable routing and dash switch layout. Triumph 2
J TR4/4A TR4 Speedometer cable routing Triumph 0
TimK Speedometer Cable Routing - BN7 Austin Healey 2
HEALEYJAG 100 speedometer cable routing Austin Healey 5
6 Speedometer Cable Routing Austin Healey 2
B Speedometer Cable Routing Question Austin Healey 3
G Routing the speedometer cable Austin Healey 4
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
P TR6 Jumpy Speedometer cable Triumph 4
S BJ8 Speedometer Cable Austin Healey 6
S Speedometer Cable Spridgets 5
P TR6 speedometer cable Triumph 21
R TR2/3/3A TR 3A Speedometer Cable Route Triumph 12
KVH TR4/4A Long Speedometer Cable for OD Transmission Triumph 10
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
C TR2/3/3A Speedometer cable fastener locations Triumph 14
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
K TR2/3/3A Speedometer cable fittings? Triumph 4
B TR6 Brand New Speedometer Cable breaks Triumph 5
Patrick67BJ8 Speedometer Cable-5-speed Trans Austin Healey 6
R Smitty Speedometer Cable Fix Austin Healey 1
O TR2/3/3A TR3 Speedometer Cable length? Triumph 5
G TR4/4A tr4a speedometer cable Triumph 9
angelfj1 Speedometer [cable failure] and repair Triumph 5
longbridgehealey Speedometer cable not spinning Austin Healey 15
T Quesiton on A-type OD speedometer cable fitting Triumph 12
D speedometer cable Austin Healey 17
T TR4/4A TR4 Speedometer Cable Triumph 3
bcbug Another speedometer cable replacement question Spridgets 4
bighealeysource T-Series Stuck speedometer cable on TC MG 3
J Speedometer cable issues? Austin Healey 7
V TR2/3/3A TR-3B Speedometer Cable Triumph 6
gubba speedometer cable right angle adaptor Triumph 4
JPSmit speedometer cable question Spridgets 8
Sarastro Source of a good speedometer cable? Spridgets 5
S Speedometer Cable Installation Problem Austin Healey 5
Magyar Speedometer and cable Spridgets 5
S Lubricating Speedometer Cable Austin Healey 13
T Speedometer cable Triumph 0
2wrench TR6 '74 TR6 Route of speedometer cable from overdrive. Triumph 7
walshja speedometer cable Spridgets 9
S TR2/3/3A Speedometer cable tr3 Triumph 3
C speedometer cable issue MG 2
T Speedometer and cable Triumph 2
W speedometer cable and housing MG 7
I TR6 TR6 speedometer cable Triumph 3
