I was going to use the OD stalk switch in my '74 to send power to a relay for foglights.
I notice that it takes its power from the alternator light. Since my engine is out, I put power to that terminal on the alt connector and get only ~6V out at the yellow wire both in the column connector and under the hood. The white wire in the column connector is also 6v.
Is it possible that I am getting a strange result with the wiring diconnected? Also, when the alt light goes out, how does current flow to the OD wire?
Thanks
Thanks
