Wiring Question, Adding Reverse Spotlight
theleisure
Bronze
Hi guys,
The gearbox I'm about to install has a reverse light switch that I'd like to take advantage of. I bought a spotlight that I'd like the switch to activate but I have almost no experience with wiring. I am able to read a wiring diagram and fix minor problems but I don't really understand them enough to add to what's there. My 66 sprite didn't come with reverse lights so I'm not sure where to tap into my harness. So you know what's there, the reverse switch on the gearbox has 2 wires coming out of it right now, as i recall they're both green but I might be wrong. Any input would be appreciated.
Thanks
file.php
Sarastro
I'd tap into the switched power at the fuse block. If I'm looking at the right diagram in my Haynes manual, it should be a white wire from the ign switch to the fuse. I'd come off this point, add a fuse, then wire to the switch, and finally from the switch to the backup light. The other terminal of the light is grounded, of course. Use at least no. 14 wire and the fuse depends on the current drawn by the light--if it's a small light, like a tail light, I'd use 5 amps, otherwise 10 amps. Of course, route the wire where it won't chafe on anything or get snagged--this probably will require more thought than anything else.
Scott_Hower
Can you define "spotlight"? Like a Lucas 576, or a smallish rectangular jobbie?
The gearbox switch will control when the light comes on, but you need power to it and from it (to the spotlight) and a ground for the spotlight itself. Preferably fused and ignition switched. I don't have my Lucase code handy.
If this were mine, I'd probably use a relay, depending on how large of a spotlight. As mentioned, fuse the circuit at 5 or 10 amps
JPSmit
If you're talking reverse light (as opposed to spotight - which seems big) I had my actual reverse lights removed when I had the bodywork done as they (the square ones) seemed a paricularly inelegant solution. Instead I have a signal light from a motorcycle which hangs under the bumper and (to my mind at least) looks very pretty. When I came to install it at that end, I doscovered on the split bumpers (don't know about the full length) that there are actually holes in the bracket that fit the light bracket perfectly - no drilling. I then ran the wire through the body along with the license plate lights and it fits easily.
Basically you need a power feed - the suggestions so far are great - the actual feed in later cars runs off the same line as powers the brake failure light circuit. (don't know if you have that)
This power feed will attach to one green line on the tranny switch (doesn't matter which as it is a switch) the other green line from the tranny will go to the rear of the car into the light and the second line coming out of the light will go to ground back there - probably against the nut on the tailight unit. Hope this makes sense. I can post a picture of what mine looks like if you are interested. They were a pair of generic lights at my handy motorcycle shop - cost about $20
theleisure
theleisure
Bronze
Thanks for the suggestions. I tried to post a photo in my first post but I guess I haven't figured that out yet... Here's a link to a picture of a rear spotlight like the one I'm installing. It's big-- 5" I think. It's going to be mounted on a bracket between the license plate and the right bumperette. I'll (try to) post pictures as I go. Who knows, maybe it'll look stupid but at least I'll give it a shot.
Pythias
Check the laws in your jurisdiction. Such lights pointed backwards are likely illegal.
texas_bugeye
Check the load on the lamps you intend to use. If its anything more than a 1157 type of bulb I would consider running it with a relay. I would think the tranny switch could not take more than a tail light bulb or two.
BugEyeBear
Definitely use a relay...
JPSmit
I agree RE: the relay. was thinking about the size and possible legality as well as the fact that you could seriously p*ss people off with a reverse light that bright. One thing you might consider is a "factory" reverse light plus the spotlight. I would then put a bypass switch on the spotlight to use only when you want. Then you have satisfied safety/ legality and coolness.
BugEyeBear
I used to have a white fog light mounted center rear below the bumper on a car I had back in the early 80's. (I used to back up a long dark driveway nightly so the extra light was a big plus!)
This light was activated by a relay, triggered by the existing reverse lights.
To twart any possibility of getting a ticket I used to carry an elastic fog light cover, just in case I ever got pulled over by a cop having a bad day...
"Cheers!" :cheers:
-Bear-
B TR4/4A Basic Wiring Question Triumph 35
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
R TR6 Starter wiring question Triumph 6
nichola TR6 Question on new wiring harness Triumph 6
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
JPSmit Todays question - wiring Spridgets 14
ckeithjordan TR2/3/3A Wiring Harness Question[s] Triumph 10
C MGA Wiring harness question MG 7
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
BoyRacer Wiring question for alternator conversion Austin Healey 3
G TR4/4A Front Parking Lamps Wiring Question Triumph 5
T TR2/3/3A Question on wiring Denso alternator through ammeter Triumph 4
Griz Trafficator Wiring Question Austin Healey 16
Michael Oritt Wiring question Austin Healey 5
N Spitfire alternator wiring question Triumph 1
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
K TR2/3/3A Another question about pulling the wiring thru the stator tube... Triumph 15
J TR6 '73 TR6, Wiring Question. Original Owner Triumph 5
AngliaGT '74 Midget - Wiring Question Spridgets 2
Willie_P TR4/4A WIRING question: gear reduction starter Triumph 3
B Question about Dual Polarity Electronic Fuel Pump - How to Connect Wiring? Austin Healey 9
TomChar TR6 '74 brake failure / oil pressure / ARV wiring question Triumph 19
B TR6 Wiring question Triumph 11
Tinkerman TR2/3/3A Front turn signal wiring question on my post 60000 TR3A Triumph 8
D Original BN6 / BN7 Battery Switch Wiring Question Austin Healey 15
T BN-1 Wiring Question Austin Healey 3
Griz Rear Wiring Harness Question Austin Healey 6
Griz Another BJ7 Wiring Question Austin Healey 4
M Quick tachometer wiring question on a '65 Spridgets 10
Tugboat Wiring Question Triumph 6
glemon Wiper Motor Wiring Question Triumph 11
bash Alternator wiring question Triumph 5
B Another wiring question 57 smallmouth control head Triumph 2
B Question on OD wiring harness 57 Smallmouth Triumph 15
Tinkerman TR2/3/3A Wiring question TR 3A Triumph 4
T TR4/4A White wire question on TR4A A-type wiring Triumph 2
Tinkerman TR2/3/3A Wiring question TR3A Triumph 5
M_Pied_Lourd TR2/3/3A TR3A Gauge Cluster Wiring Question Triumph 7
R TR2/3/3A TR3 Headlight Wiring Question Triumph 6
R Wiring question. No spark, need help. Spridgets 16
Coyote1 Overdrive wiring question Triumph 8
T Wiring hack - iginition switch question Spridgets 8
B wiring harness question: Triumph 3
E BE Alternator Wiring Question Spridgets 5
hondo402000 TR6 Another TR6 wiring question Triumph 5
hondo402000 TR6 TR6 Wiring/amp gauge question Triumph 8
T TR4/4A TR4A alternator conversion wiring question Triumph 28
T OT Wiring question - but probably useful to know Triumph 10
Tinkerman TR2/3/3A Wiring Harness Question on my TR3A Triumph 8
