I have a strange problem with my inductive timing light. It is a Stinger by OTC. It has all the bells and whistles; dwell, RPM, adjustable advance and voltage. I have painted the TDC mark on my damper. When I take a reading, it looks like 15 degrees ATDC (mark on damper above timing cover mark as viewed from the right side of the car). If I dial in 15 degrees of advance on the timing light, the reading doesn’t change. If I rev the engine, the reading doesn’t change. If I rotate the distributor, the reading doesn’t change (I did this with the sparkplugs out). I’m using a multi-spark electronic ignition, but I wouldn’t think that would have an effect. Any thoughts of what I might be doing wrong? The directions are a little less than and there is no troubleshooting guide on OTC’s website. /ubbthreads/images/graemlins/computer.gif
Thanks,
Greg
Thanks,
Greg
