Something weird with the idle/throttle
DesertSprite
Hello once again,
Okay, here's this weeks problem:
Driving around town for a while, I slow to a stop and the car begins to sputter and lose it's idle, then it just stops completely. The car was warmed up, driving fine beforehand. When it died, it seemed to trying to maintain the idle as it sputtered.
Weird thing is...I pushed a couple of feet just to get it out of the way of parking lot traffic, then tried to start it up...boom, fired right up. ??
Drive it maybe a mile down the road towards home and it does it again. This time in between shifts (1st to 2nd). As the RPM's were coming down it just lost it's ability to stay going.
Being that my Wife was with me and we were headed out for the day, I got it home and put the cover on it and took out the 4Runner. So, needless to say I haven't had anytime to check it out yet.
I'm thinking it might be some kind of vaccum leak or something. The thing has been idling quite high lately. I'd say approximately 1200-1300rpm's at idle.
Any ideas?
Mahalos,
Joel
/ubbthreads/images/graemlins/thirsty.gif
tony barnhill
Great Pumpkin - R.I.P
What type distributor you running?
tony barnhill
Check your condensor
lesingepsycho
ballast resistor?
JACK
Platinum
Runs fine then konks out... does it again after another spurt... Sounds fuel-ish to me. 25D, points 'n condenser I'd expect to just ~quit~ and not start again. Condenser is cheap at NAPA, A/Z, etc. tho. Swap it out and see.
Fuel pump demonstrably good? I'm just stabbin' here, so pardon if that seems silly.
jcatnite
I was thinking fuel too doc. I was wondering if the fuel tank vent wasn't possibly stopped up some how. Could be a lot of things, as usual, I would rule out ignition problems before doing much else. A clogged fuel filter did to me, exactly what Joel described. When I bought my car, it had a rusty tank and the PO "fixed" it by installing a small filter between the tank and the fuel pump. Took me a bit to find that one...lol
JC
Platinum
I know this is a segue, but: has anyone ever put a pressure gauge in-line to SEE what it is 'normally' while running? I may do that just fer S&G's. That "curiosity" thing again.
jcatnite
I did but, I've got an aftermarket electric fuel pump on mine. Seems the rust in the tank kept trashing those "expensive" mechanical pumps(PO's exact words). I kept about 3psi through the entire range of engine rpm. The car ran extremely rich when I bought it and I was wondering if the pump was overdriving the needle in the carb. Not the case for me though, the over rich was caused by an eroded needle coupled with pitted points and spark plugs that looked like they were installed by Fred Flintstone.
JC
Platinum
Neat. Good "telltale".
DesertSprite
I have a new condenser right here and I have a new fuel pump as well, so I guess I'll swap those out and give it a try.
Fuel pump seems to be working fine to me. But then again, I'm no expert here. When I turn the ignition to "on" I can hear the fuel pump doing its thing, but it doesn't sound like anything is wrong with it.
Unfortunately, this might have to wait until next weekend as I'm going out of town this weekend. Don't you hate that? You want to drive your Spridget on Friday to work because its supposed to be nice, but then it craps out on you. /ubbthreads/images/graemlins/frown.gif
mahalos,
Joel
Platinum
A good reason to have more'n ONE! /ubbthreads/images/graemlins/devilgrin.gif
drooartz
I've started to think that having 2 LBCs might be a good thing. Of course, not sure my wife would appreciate it, and I'm too big to sleep in the Tunebug!
lesingepsycho
I don't know anything about the Lucas Sports coil but if it isn't internally resisted, it will still scorch the points and cook the coil. After a bit of driving, (it was about 20-30 minutes with my car) the coil heats up from getting too much voltage, that extra heat is then passed on to the condensor which can no longer keep the points from arcing and you start losing you ignition little by little. After 5 minutes or so of sitting, things will cool down and then you'll be able to drive for awhile again. It took me YEARS to diagnose this problem and I replaced EVERYTHING in the fuel and ignition systems at least TWICE and all along it was a $10.00 ballast resistor. It's certainly worth checking out is all I'm saying! My car has never broken down since I installed a ballast resistor whereas it used to break down everytime I drove it.
JACK
DesertSprite
Jack - I'll certainly look into it, but I was told not to install a ballast resistor in the ignition system if the car was never originally equipped with one. ??? I don't know. It seems like this ignition nightmare won't go away.
DrEntropy - if you can convince my Wife to let me buy a nice E-type here in a few years, I got no problem with owning 2 LBCs!
Joel
Matthew E. Herd
Joel, if your original coil had a ballast resistor internally, then you wouldn't have had one that you knew about. However, if the sports coil which replaced it doesn't have one, then you'll need to add it. One good way is to measure the resistance of the coil. However, I don't remember what the numbers are.
Bugeye58
The sports coil is an internally ballasted coil. Typical resistance readings are in the 3.0 Ohm range. An externally ballasted coil will Ohm out about 1.5-1.6 ohms. DO NOT install an external ballast resistor on an internally ballasted coil.
Jeff
Jim_Gruber Something weird electrically with Bugsy Spridgets 7
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
T MGB Quick question about something that don't really matter just want to know. MG 9
Simmo TR2/3/3A Something is eating away at my Piston Liners Triumph 15
V MGB Mystery fastener from '66. Did I miss something? MG 6
K TR2/3/3A The latest "It's always something." Triumph 8
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
Sherlock Something Swedish... Something German... Spotted 3
PC something really cool, and a Ferrari Spotted 11
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
JPSmit and now for something completely different Spridgets 8
GeorgetheTR3 TR2/3/3A Bonnet popper, or something like that. Triumph 5
AngliaGT Something Different Spotted 3
JPSmit Worth Something Somewhere else Spridgets 7
Got_All_4 General TR [TR6] Fortunately For Something to Live Something must Die Triumph 1
J Found something new on a Healey engine Austin Healey 3
2 TR2/3/3A Something's burning Triumph 13
Got_All_4 TR2/3/3A Something is really wrong? Overdrive Tranny Triumph 7
bcliff MGB Are you looking for and MGB Roadster or maybe something else. MG 5
Got_All_4 TR2/3/3A Need measurement from front to rear axels something weared happened today Triumph 7
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Jer when something doesnt make sense... and you finally figure out why ! Spridgets 4
B Valve Cover Plate Rivets: Useless junk or am I missing something? Austin Healey 10
David Townsend TR2/3/3A And now for something completely different Triumph 2
steveg Learned something about rear axle seal Austin Healey 3
B Installing New Leaf Springs on 100-6 - Am I missing something obvious? Austin Healey 19
DrEntropy Something happy-sad... Racing 0
V TR2/3/3A Something Different Triumph 20
Boggsy64 MGB King Pins appear fine am I missing something? MG 3
dklawson Oil Leak - I Screwed Something Up. Triumph 8
D Finally got something done... Spridgets 8
60TR3A Learned Something New Austin Healey 16
Nunyas Not something you see everyday... Other Cars 10
M_and_P Thinking of doing something funky with the Mini British Motor Corp 6
kurts100 Am I missing something? Triumph 8
Anthony_S Something to look at Triumph 4
TR6BobNF Lotus - Forgot Something Spotted 4
B Who knows something about this? British Motor Corp 5
6 HELP! something broke in the rear end... Triumph 71
JPSmit Learned something new today Spridgets 3
Trevor Jessie I posted something in the classifieds! Spridgets 0
tri_carb_healey i did something stupid Austin Healey 13
Sherlock Something a little, ahem, different... Other Cars 3
drooartz I fixed something! MG 17
M TR6 This is something I should know,but don't TR6 Triumph 5
Hap Waldrop Something I need to say Spridgets 32
S And now for something COMPLETELY different...... Other Cars 7
jlaird Doing a bit of something. Spridgets 26
jlaird Miss Agatha was trying to tell me something Spridgets 4
S Something you don't see everyday..... Other Cars 19
