TR2/3/3A Need measurement from front to rear axels something weared happened today
Got_All_4
I had about 10 miles on the rebuild and I thought it drove well with out an alignment. On my way to the tire shop today I heard a snap come from the rear right side. Car became a little hard to handle when I would shift. Kind of like torque steer. The shop couldn't get the car on the alignment rack so he wasn't able to align it or check out the rear end.
Back home I put it on jack stands and discovered that the U bolts on the right weren't super tight and one stripped when I tighten it. I find it had to believe though that the rear end was moving around that much but it's possible. Decided to measure from the front axel center line to the rear center line. 1" difference between sides. Driver side was 87&7/8" and the passenger side was 1" longer. How this can be? I did put in new Super Pro bushings on the front and rear ends and no other major work was needed done to the frame. Also I had been driving the car for 30 years with no problems.
So I could really use those measurements and any ideas for trouble shooting?
TR3driver
Great Pumpkin - R.I.P
There is a bolt through the center of the spring, with a short rounded head on top (no wrench flats). That head should fit into an opening in the pad on the bottom of the axle. If it slips, the axle can move fore/aft on the spring.
The pad is just bent heavy sheet metal, and can be distorted by improper installation. If it is bent in until the bolt head doesn't enter the hole, you'll want to fix that.
TexasKnucklehead
Gee that's a really difficult request. I don't know where the "front axel center line" is, within an inch from side to side. But I can assure you, the alignment of the rear axle is mandated by that bolt through the rear springs and the hole in the plate tightened by the u-bolts. The top of that bolt fits inside the bottom of the axle while the bottom fits into the plate that also supports the shock arm link. If your u-bolt stripped when you tried to tighten it, it needs replaced. If that u-bolt was loose, and the bolt through the springs came out of the bottom hole, the plate will not longer be flat on the spring bottom. If the top bolt came out of the axle (or plate) your alignment will be off.
If your front to back is off by an inch, your tire may not be able to come off. -This past week I helped replace a set of leaf springs on a TR3. One spring had the pin/bolt location off by an inch rearward, which was enough that we could not put the wire wheel back on the hub due to interference with the fender. An inch is a lot.
If I were you, I'd be looking very closely at the u-bolts and that pin through the rear springs. You might be able to find a more easy measurement from something like the mounting pin of the rear spring.
TR3driver
I agree, focus on getting it put together right first, and then if necessary you can worry about thrust alignment.
That said, the book gives the wheelbase as 7' 4" which should be axle center to axle center. But don't forget that when comparing sides, the steering must be in exactly the straight ahead position. The front axles actually move fore/aft as the steering turns.
Got_All_4
Got_All_4
Ok did all that. The axel centering bolts are in the holes and I checked that first before trying to tighten the U bolts down and new ones are ordered. Front wheels were straight a head when I measured but it could be possible that the wheels are turned ever so slightly that could make up some of that 1" difference. I'll double check everything this weekend and plan on stacking a bunch of washers on the U bolt to get past the stripped threads in order to tighten them down and test drive. So between the to centers it's 88" and I'll have to get as close to that as possible.
Got_All_4
Got_All_4
Thanks for your concern GEO but as I said new ones are on order and the "stacked washers were just going to be a test to see if I'm on the right track in which I just completed and everything is back to normal. Loosened everything up and realigned it. Made sure the front wheels were as straight as I could get them and my measurements came with in a 1/8 inch of each other. Test drive went great. Now I've got to find someone with a narrower alignment rack.
J TR2/3/3A Need a measurement on a steering column please Triumph 2
BlueMax Need a Measurement? Spridgets 2
Coyote1 Need a quick measurement Triumph 7
I TR6 Need measurement for tr6 kidney pad please Triumph 4
GregW Woops! need another measurement Austin Healey 8
64rocksprite RWA owners..I need a measurement Spridgets 20
A TR6 Need TR6 shift lever measurement Triumph 4
Jack_Long Trim question - need a measurement Spridgets 5
tr6web TR6 Need advice removing downpipe nuts Triumph 0
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
